OT Another offbeat shower valve question
I mentioned I am flipping a house. Selling it As Is. Usually I buy them and spend about $30,000 on them and then sell them. This one, I just hauled away the junk , cleaned it and put it back on the market at a deep discount. Went to turn the water on for the Home Inspection (Got a contract) and discovered all the copper pipes had been stolen. I decided that No One thought As Is meant "there is no plumbing." The thieves had even broken most of the plastic drain lines to get to the copper. So I have spent most of three days restoring the pipes. I was very pleased to discover I had no leaks in my work when I turned the water back on.
Now for the question. When I tried the tub faucet I got nothing on the cold side and about half flow on the hot side. (it an old fashioned two handle faucet) I checked the shut offs and they were on. I fiddled with it several times. Then, I turned the hot on first and the cold at the the same time. It gushed. So, if you turn the hot on first, the cold will work. But, if you turn the cold on first, you get nothing. I will have to go back and look, but the shower diverter is on the tub spout.
Some internal part is stuck. I think. Any suggestions?
