OT Another new use for the Impact driver????
I am flipping a house. I turned the water on for the Home Inspection and discovered the garbage disposer was seized. It just hummed. As a Home Inspector myself I know from long experience if you leave it on for more than a second the thermal over load will trip. I also know that if you can get it going it will function. I tried an Allen wrench and even with a cheater bar all I could do was turn the entire unit. Chucked a short piece of 1/4 hex stock into my little 12 volt Bosch impact driver and gave it a jolt in forward and then in reverse several times. Tried the switch again and it spun about a 1/4 turn. Back to the impact driver and finished shacking it loose. Ran some water through it and ran it several times and it seems fine. Why was it seized? I see them all the time. This one had been sitting unused for about six months.
(This house was sold at a deep discount and "as is" with no mention of the presence of a disposer. So, whatever they get out of this one is a freebie.)
