Powermatic 143 motor size?
Paul Grover
What hp does this bandsaw need? I have a new lesson 1 1/2 hp motor. It is not enough power to resale 3" hard maple.all bearings and tires are new. Any suggestions are appreciated. Thanks Paul
Re: Powermatic 143 motor size?
Forrest Addy
Single or three phase? I think 1 1/2 HP is as big a single phase motor as you'l likely find in a NEMA 143 or 145 frame Next size up is NEMA 182. Can you drill some new holes? The motor case isn't that much larger dia but it will be longer. If you have room and you can re-drill the motor mount to suit a larger motor you can put in a whopper motor. 3 to 5 HP isn't any too much for re-sawing gnarly woods
Look here to comparison shop:
http://www.baldor.com/catalog#category=315
Pricy.
Re-sawiing, right? Any reason you can't rip your 3" maple on a table saw with a thin kerf blade? I use to rip 28 - 30/4 western red maple from each side leaving about an inch in the kerf to hand saw. Tolerable for 6 feet of cut but increasingly tedious thereafter
Paul Grover
I could rip on the table saw,I do prefere using the band saw.l will check the bald or site. Drilling holes in the base wouldn't be a problem. Thanks Paul.
John in NM
I would have thought 1 1/2 HP would be sufficient, have you tried it?
The 143 is a nice saw, those old cast iron framed saws are keepers! :D
what size pulley's
del schisler
i have a 1 1/2 horse on my delta 14" with riser and can saw any size i want and not bog down motor, , here is my set up my motor is a 3450 , i use a 1" on motor and 6" on saw , also the pulleys are double belt drive and browning iron pulleys , works for me for yrs now
Paul grover
The motor is a new lesson 1 1/2 hp,wired 220. All the bearings in the gear box, and the wheels are new.yes. It's a sweet saw,the C frame is a one piece casting. I had a 141 wit) a 1 hp motor ,it would resale about 5 1/2 " . The blade on the 143 is a new Forrest 3 tip. Thanks Paul
Re: what size pulley's
Paul grover
Pulley is 2"" which was orgonal to the saw. The belt goes from the 2" drive pulley to a about a 6"" step pulley,then to the 2 speed gear box.this machine is for metal or wood.the original motor was a 3/4 hp 3 phase. Thanks Paul
Paul grover
I do have link belts,and single pulleys,I noticed that the belt directions are different,I don't know if this matters,but I will correct this.Paul
