Re: Sears Drill press overhaul
Ralph Lipeles
It should be pretty straight forward. The only tricky part might be the return spring. It might have a preload that you will have to duplicate at reassembly. Try to get a parts list so that you can put the disassembly in perspective. Take careful notes on everything that you do. Pictures are also a help. I usually put the parts in plastic bags or use pieces of masking tape to assign part designations. Clean the parts with kerosene or mineral spirits. Inspect the parts to determine if any might want to be replaced. Parts are sometimes available from Sears, Independents or eBay. Bearings are standard and replacements can be obtained from a local supplier or on the internet. Reassemble in reverse order of the disassembly.
I've done a couple of drill presses. I like to clean up the column with sandpaper or coarse steel wheel. A also paint the base and any cover plates with grey spray paint.
If you don't have a parts list, look on the internet, eBay or post here for it.
