13" delta planer snipe
Bill P.
All of the sudden I am getting some snipe on the left side on the entry end of the board. The blades are very near to the end of their life so I ordered replacements to see if that would help. In the mean time is there something that should be looked at for the cause. I've pulled, pushed and wiggled everything I thought might be the cause but everything seam tight. Although it does seem a little louder than when new but it is somewhere around 10 years old. Any ideas would be helpful.
Thanks, Bill
Re: 13" delta planer snipe
Keith Newton
Snipe is usually caused by presentation of the board. If it is on the front end, you have the trailing end too low, so lift it a little higher back there. And always give the board a little lift as it gets to the end on the out-feed also.
The worn blades may be coincidental. Usually, as Keith mentions, the boards are tipping. This is more likely with longer and/or heavier boards. Is this likely to be your situation?
Many years ago I had a Delta 12 1/2. A small mod made it pretty much snipe-free. All I did was ensure that the extensions were coplanar with the base, and that they could not flex.
Hex bolts acted as height adjusters and inflexible rests ..
Bruce, a MN Galoot
Without a cutter head lock it's very difficult to eliminate snipe. I have an older version of your planer, and what I've done is to make a supplementary bed for mine. I took a 4' long piece of plastic laminated particle board and fitted it between the bed guides. It extends about 1-1/2' beyond the infeed and outfeed and that has helped tremendously. Still, lift the board a little as you feed it in and as it exits the planer. Also use a sacrificial board in front and behind the board. I agree with the others that the left side snipe is a presentation problem.
I agree with all of the above.
Another thing I did to eliminate snipe on my Dewalt version of the planer was to change the bearings on the Rollers. They are not ball bearing, but some sort of graphite impregnated blocks (Or some such thing). The ones on the left side had worn an elongated hole in them. IIRC I replaced all four. I also replaced the drive chain that had developed a bad link that woudl occasionally get hung and cause a skip or jerk in the process. That may have been what caused the elongated wear.
As mentioned above, leveling the tables and making them sturdy is important. If anything, you want then to be a hundredth or two high at the ends.
You can also use a long "platen" with a slick surface passed through the planer and secured with a cleat behind the table to keep the work steady and level.
And feeding a longer piece of stock on each side of the work will help. These ideas were mention before but bear repeating. Taking light passes will help too.
Bill P
I replaced the blades and nothing improved so I dug a little deeper into it. What I found was a couple loose bolts holding the rollers. When I pushed on the rollers I couldn't feel any movement but apparently there was under pressure. Now when I ran a 7 inch board through the planer it's only a few thousands difference in thickness from side to side and the snipes all but eliminated. Hopefully that does it, I really didn't want to spend the money for a new one even though it would be nice.
don stephan
Taking the thinnest possible cut will also reduce the amount of snipe.
