Have a question? Ask Woody!
Matching Store Displays
Don Stephan
A local store asked for a quote to make more display boxes matching what they have. The existing are made using stained roughsawn actual 1" by actual 4". Neither a true lumber yard nor hardwood supplier carries anything like this here in Cincinnati. Because of the stain I can't identify the wood. Anyone have an idea what this might be? It certainly is possible if not likely the display boxes were factory made.
Re: Matching Store Displays
Keith Newton
If you can't tell, then just get the cheapest wood that will stain the same. Poplar or Soft Maple would be good and easy options, moderately priced, for my location.
rough sawn lumber
Dick Coers
Ask your hardwood supplier for rough sawn lumber. It will be a full 1", likely slightly thicker. Look for a local sawmill, or contact Woodmizer and they will direct you to a local sawmill. Many of those people also have dehumidification kilns to sell kiln dried. A picture would let us help you even more.
don stephan
From a couple sources I purchase rough sawn lumber here in Cincinnati all the time, usually cherry, maple, poplar, and walnut. But the boards are not the very consistent thickness and surface texture of the boards in the store display. I'm getting more and more suspicious that the displays are mass produced by a factory the dresses "rough sawn" lumber to actual 1 by four and then adds the rough sawn texture via machinery and builds the displays. The edges of the boards look evenly slightly rounded, furthering my suspicion. Rough sawn cedar at a local construction lumber yard does not have nearly the consistent roughness of the boards in the existing displays.
Wire-brushed?
There's a lot of texturing done in the wood industry, including one technique called wirebrushing, which results in a texture like you're describing. Woodfinder® doesn't turn up any sources, probably because wirebrushed lumber is almost always softwood or salvaged softwood, and the finished product is most often used for house siding.
I wish I could point you to a source, but I'd start with a traditional lumberyard and see if they have a connection that can provide you with this stuff.
