Fixing an edge ding
Fixing an edge ding
Fixing an edge ding
This board was just long enough, wide enough and had proper grain for the feet of the chest of drawers I am building. But as I was preparing it for the feet I noticed a small gap where the edge didn't clean up from its rough state. A quarter round is going to sit on the top of this board but this dinged edge will show. I was motivated to use this piece of wood and tried something I have contemplated before.
I chiseled the ding so it had a flat smooth surface. Prepared a thin strip of cherry, slathered on some glue, let it dry a bit to be thicker and clamped it in place. Clamping was a challenge but I found an orientation that was successful. It worked.
Re: Fixing an edge ding
Very satisfying....
John in NM
I love these kinds of fixes, aren't they positively fun to pull off successfully? :D
William Duffield
If I can't fine a way to clamp a patch like your example, 3M blue tape works. It has enough stretch to put sufficient pressure on the joint, even if using yellow glue.
Kneale Brownson
Kneale Brownson
Since I'm a klutz, I'm often trying to fix such issues, and can verify that painter tape can hold the glued-on bit sufficiently for the glue to cure so the fix can be completed.
Re: that would have been a better idea
William Duffield
If I'm using yellow glue, and making a large patch, or a structural repair, the blue tape may not apply enough pressure to get a good bond. If I couldn't get a clamp properly applied in a case like that, I would probably go to the extra trouble and curing time of liquid hide glue or even epoxy.
We call 'em "Dutchmen"
I can't think of many projects that don't end up needing a little patching here or there. For edge patches, I agree with the painter's tape clamping routine. This is a common approach when installing purfling around edges of things.
Krenov didn't abide patching at all. I once heard him compare it to "covering mistakes like a cat covers his droppings in a litter box." Struck me as funny.
Steaming?
Hi Bill
Was this a hole or a ding? A hole needs filling (and I think you did a super job), but if it was a ding, did you consider steaming it out?
I wrote a short description of this on my website not so long ago:
http://www.inthewoodshop.com/Furniture/DentRemoval.html
Here is the ding needing work ..
Wetting first and then steaming with a wet rag ...
A light scraping and this is the result ...
Steaming with a Weller soldering iorn
I don't know if they are still made but one of the Weller soldering irons that looks like a black pistol is ideal for steaming. The tip heats quick and hot. I keep one at hand and inside its case is some old fashioned lead solder (for soldering) and a cotton rag for steaming. As long as the grain isn't torn or missing steam typically saves the day.
