Knife handle question?
When My son went to Baghdad with the army I gave him a Randall knife. That was about six years ago. Now he wants to send it back to the maker to have it refurbished. He wants them to install a wooden handle. They will, but you have to send it. Asked me if I had any ebony. I do and will happily give it to him, but I am wondering if that is the best choice.
The question is what would be a good choice? African Blackwood? Macasar Ebony? Amboynia Burl?
Re: Knife handle question?
Any close grain resilient wood would work.
As to what would be the best - whatever wood that you have that you like that fits those characteristics.
I've made scales out of rosewood, African blackwood, hickory, cherry. They all work.
TomD
The best would be an impregnated diamond wood, there are versions that look pretty much exactly like ebony, or anything else you like, yet the material is durable for the environment a Randall was intended for. There is an un-impregnated diamondwood also, and it is more likely to crack. Great thing is this material takes a polish no infill. I work with ebony for classical guitars all the time. I have abow with the fake ebony in the riser. I can' tell the difference in the look or feel (it is heavier, but on this particular bow that is hard to tell). I have made planes out of it, which turned out to be pretty nasty, not least of which because I got a really weird colour of it.
Try these guys for other options:
http://www.knifekits.com/vcom/index.php?cPath=40
Diamondwood is made by:
http://rutply.com/404e.html
I don't have a diamondwood supplier at the moment, I used to get it from Craft Supplies, they now sell the unimpregnated material. The stuff is ubiquitous. In duck calls, and parts for pen turning, and so forth. But getting a larger chunk might require some investigation.
Did you see.....
Rutland Plywood, the maker of Diamond Wood burned down about two years ago? The site said the woudl post their progress, but I did not see any updates. Are they out of business?
John in NM
Tom's post reminded me about stabilizing - there is an outfit in AZ I use to get burl stabilized when I need it. I've run a stabilized cherry cutting board through the dishwasher with no obvious effect (other than cleaning :D )
Might not be worth doing to something like ebony, but worth considering if you want to use a less dense wood.
Philip Duffy
very good advise, John. Philip
PAUL WOOLSON
Ebony would certainly make a fine scale. I've used a LOT of ebony in my career. One of the big drawbacks is that it simply looks like plastic (especially when finished).
I'd be inclined to suggest something like rosewood (East Indian would be a fine choice) that would be dense and oily yet still have some aesthetic characteristics. Macassar Ebony would work but the lighter colored areas are much softer than the darker. (It's not a sapwood thing, the grain works that way in my understanding). Pau Ferro (often called Bolivian Rosewood) would be a good choice if you are leaning more toward the browns rather than the purples of East Indian.
John Veerkamp
Osage Orange is a good dense wood that finishes wonderfully. It is bright yellow/gold when fresh with chatoyance.. As it ages with hand oils it develops a rich amber color, like a gem
Re: Did you see.....
TomD
Yeah, I saw that. It may explain some of the shortages, though there is a ton of product out there, and it is coming from somewhere. There is someone selling a scrap of ebony Diamondwood on ebay, though I assumed it wasn't enough for your project, but then I don't know. Also not sure what the grain orientation on that piece is.
Local stores sell coloured laminates, but not impregnated. Shopping in Canada, one might as well be in Namibia, so in the US you should be able track some down.
Boyd's is still selling stocks, but they use the partially impregnated stuff. It won't take stain, so it is somewhat water resistant. Boyd's used to sell raw also.
TomD
There are stabilized products in the Knifekits URL I posted. They often stabilize burl because it is very permeable, looks fabulous in some colours. I doubt they could stabilize ebony, it is so dense, it almost cuts like plastic and it doesn't need finish. It is nature's stabilized wood, though not probably dishwasher safe.
How about cocobolo? I like the figure which is missing in most ebony. B&W Ebony might be nice if you had the right piece. I could send you cocobolo pieces in an envelope if you want.
Dogwood is another option - the more it is used the smoother it gets. We've made pens with no finish and they "weathered" well.
I once took a box full of offcuts suitable for handles to a knife maker. Most were exotics. He almost cried.
Re: Knife handle question? *LINK*
John in NM
For one knife or two, a supplier like knife kits would be the way to go....
For a bunch, the supplier I've been using is K & G Finishing in Pinetop AZ. They're pretty reasonable really, though I'm getting the cheapest price since I'm usually getting more than 10 lbs done.
They advertise a thin resin for dense woods, but since I'm always getting burls done I've never tried it. I agree ebony and the like really doesn't need it.
Last time I sent a batch, I cut up a bunch of scraps into pen blanks and small blocks for knives and such. They're still sitting in the box :D One day I might get around to listing them on ebay.
https://www.knifeandgun.com/SearchResults.asp?Cat=71
Thanks, He wanted the knife handle to be....
"an ecological travesty". He's a funny guy. Proud of him. He has made Major and is attending Command College or as some call it Charm School.
