OT Cell Phone Charging
Tom
I was wondering if it is possible to charge a cell phone with a USB charger. We will be travelling and trying to eliminate chargers.
Thanks!
Re: OT Cell Phone Charging
David Yoho
Tom, I'm not sure what you're asking exactly. My cell phone charges via a USB cord to the charger plugged into the wall and came with the phone. I also can charge it while in my truck via a USB cord connected to one of the truck's USB outlets.
Are you talking about something different than what came with your phone?
walta
I charge my phones with an USB cable.
Be sure to test your charging plan before you leave home.
Once I tried your plan with a Ipad but it refused to accept any power from any non Apple power supply.
Walta
Thomas E Norton
The charger I have plugs directly into a 110v outlet. My idea is to have 1 Four Port USB charger. So I am wondering if I can charge a phone this way?
Lee Schierer in McKean, PA
USB stands for "universal serial buss" which means that all USB ports supply the same voltage for what ever is being plugged into it. However, the current they can supply may be limited so it may take longer for your device to charge. Apple devices use a proprietary connection on their devices so you have to use their cables. Most others use standard cables.
Lee
You can usually charge a phone from
- any USB power supply,
- power from the USB port on a computer,
- a USB cord plugged into an adapter plugged into the cigarette/power port of your car,
- from a USB port in many cars,
- or a portable battery made for this. (Available from Amazon)
Some power supplies have a separate USB port with a higher current output made just for Apple. I find our iPads sometimes need this by my wife's iPhone works with almost everything. Note that some cheap USB cords don't work with Apple products regardless of the power supply. Android, never a problem for me.
John Veerkamp
The apple cable will work on any USB charge device. You may get a message to the effect that you must use an apple charger to work. to true just plug it in and charge away. Time of charge may vary as others mentioned.
Jim DeLaney, Austintown, Ohio
I use a 4 port 'universal' USB charger at home, and on the road, to charge (with various cables) two iPhones; an iPad, a Nook reader, and a Samsung tablet. All work well, with not problems.
Yes, but...
Grant in Iowa
An Apple Ipad 2 must be turned off to charge in any realistic time frame from an IBM desktop. It seems Apple didn't conform to the standard at the time.
A wise man once said:
"There's one good thing about standards. If you don't like one, there are plenty of others to choose from".
Regards,
Grant in Iowa
Re: Yes, but...
Bill Howatt
The USB 1 and USB2 specification for supplying 5V is 1/2A. I believe this is about doubled in the USB3 standard. To complicate things there is now a USB "power" standard that permits higher currents but this support may not be available on your computer.
It is not uncommon for wall-plug chargers using a USB device connection to supply up to a couple of amps.
Bill
John McGaw
With any modern phone this should be possible; some ancient devices IIRC had proprietary chargers and cords. In any case, if you will be traveling widely then don't forget that outlets, voltages, and frequencies vary around the world so make sure that your charging kit is adaptable enough to cope. I've actually had to help out fellow yanks on their first tours in the UK who were unable to plug anything in.
Thomas E Norton
Thanks for all the replies. Experimented with my unlocked cell phone and it worked fine. One less charger to carry!
