Table saw top maintenance - couple of questions
Terry Alexander
About 3-4 times a year i clean off the small rust spots that appear on my table saw. Time to do that was today. After i sanded/scrubbed out the rust spots, i opened a new can of Johnson's paste wax (i finally finished my other can after about 6 years). The "new" Johnson paste wax is brown and the "old" wax was orangish. I really did not like the performance of the brown paste wax. BTW....the cans are absolutely identical.
So now the questions:
Has anybody else had any experience with the "new" johnson's paste wax or did I possibly get a bad can?
When applying paste wax (whatever brand), the t-shirt piece that i use to apply the wax turns black almost immediately. What causes this and should i keep finding a clean spot to apply the wax?
Frustrated with the Johnson's I finally broke down and used my Renaissance wax. The instructions are pretty sparse. "Apply sparingly then buff out. Hardens almost immediately." Question here is: Should i wait until the Renaissance turns to a haze (like other paste waxes) or just apply and then buff out?
Thanks for all of your valued assistance. These might be stoopid questions, but i really do enjoy my table saw and especially when the wood just glides across the table.
Terry Alexander in West Texas
Re: Table saw top maintenance - couple of questions
Lee Schierer in McKean, PA
The black you get is a combination of dirt, old wax and iron particles. I'm still using my old can of Johnson's wax so I can't help you there.
Lee
AZ in Colorado Springs
My johnson's wax is brownish. Works fine. Like Lee said, the rag is collecting crud from the table top.
john Lucas
Like you I used a can forever and I feel like I used it a lot. I use a separate rag for waxing equipment vs waxing my work. the rag does get black when waxing metal. It's been a year or so since I got the new can and I seem to remember it being a different color but I used it today and didn't even think about the color. It seems moderately light but can't remember the color of the older stuff. It seems to work just fine.
Johnson's Wax
David Yoho
I had heard some time ago Johnson's was a different color than the original but I haven't seen any yet. I bought about six cans of it many years ago when I heard they were possibly going to stop making it. I just opened a new can last week and it's orange in color. I still have two unopened cans remaining. I like to put a little in a small plastic container like yogurt was in and give it to my customers when I deliver a piece of furniture. That way they have enough to properly care for it for a while.
Not only will your cloth turn black when rubbing cast iron surfaces with the wax but also when scrubbing it with WD-40 and a Scotch Brite pad and rag. I have a partial can of Johnson's dedicated to cast iron surface maintenance with its own rag inside. I use a different can and cloth for waxing furniture.
coments and questions
"About 3-4 times a year i clean off the small rust spots" you should be waxing more frequently to avoid getting any rust spots.
" I really did not like the performance of the brown paste wax." What about it was inferior?
Make your own that is better. Buy some pure Carnuba, the hardest most durable wax know to man. At low heat, melt the wax along with mineral spirits or Xylene (from Lowes) in the Johnsons wax can. I can not remember the ideal ratio. Try 1:1 on half a can full and adjust to get a mixture when cool that is about the consistency of Crisco.
How to heat safely: I use a hot plate, outdoors, on a low setting. I put the Xylene and wax in the can, set the lid on the can loosely so that it is a bit vented and turn the hot plate to low. Then keep track of progress. Some sort of double boiler arrangement would also work fine.
Don't use turpentine. It makes a good wax mixture, smells great in the shop, but dries slowly. Might be fine for saw table tops but it dries too slow for lubing drawers.
jgdillon
Terry, regarding your Renaissance wax question, I generally do NOT let it dry to a haze as I found it can be very difficult to remove - at least on furniture. I would guess I let it dry a minute or less, then buff. On a TS top it probably doesn't really matter. Maybe I'm doing it wrong, but I sure like the end result and tactile feel of it on wood. Jim
ebd
ebd
I spray all my cast machines with WD40 after each use during spring (especially) and fall periods. My shop is unheated (except when I'm using it) and condensation is a probem. None of my tools has any rust/staining. I wipe them before use and re-spray after, anytime there might be a condensation posibility.
Recurring Rust
tells me you're either not using your tool enough ;) or your coating regimin is not sufficient for your location. If a good coat of Johnson's is not doing the job, best get you a can of Boeshield [sp] spray and apply as directed.
BTW I'd hold off on the sanding routine. The scratches are harder to seal and create the perfect environment for rust to restart faster in the little valleys.
You can also consider using some phosphoric acid (Naval jelly or similar brands) which will chemically change the rust particles to iron phosphate crystals and will resist further oxidation. My tools' cast iron tables have some darker shadows of iron phosphate crystals, but no recurring rust. I didn't buy a blanchard-ground table saw and don't need it to look like a new PM-66.
Update on original post
Terry Alexander
Thank you all for your great input.
I think Mark Mandrell's response diagnosed my original problem. I think I have dark shadows of iron phosphate crystals as opposed to rust.
Difference between the old Johnson's and the new? The new appears/feels much dryer than the original.
Yep....I do have a little OCD (is there such a thing as a "little"?).
I've been on this board for many years and feel like I got responses from many of the "A-Team"! And I do thank you all.
Terry Alexander in West Texas.
TomD
The stuff I have is white like a bar of paraffin. I now have some other brand that is brown.
