OT-Magnetic Key box
Thomas E Norton
With the new vehicle keys that have some type of electronic inners. Can you safely use the magnetic key box to hide a lkey?
OT-Magnetic Key box
Thomas E Norton
Don't think so. *LINK*
Hoa in Alameda
I think car keys use RFID transponders.
Magnetic key box shouldn't have any ill-effect on RFID.
Doubtful
On my Jeep, if the key fob is within range (as it would in a hide-a-key) either the car won't lock or it can be started and run by anyone who happens by.
Pasive RFID
Hoa in Alameda
If you remove the battery cell in the key fob, the active RFID will stop working, thus you can't start the car at a distance. The passive RFID in the key, however, still allows starting the car if you hold the fob close to the "Start" button (or the ignition lock).
Re: OT-Magnetic Key box
Way out of my expertise here, but can't you have a dump old fashioned key made to hide in the magnetic box? Then you could use the dumb key to open the car. Then you could leave an electronic key inside the car with the battery removed or wrapped in foil or whatever to isolate the signal.
Also, you can add an aftermarket push button key pad to the door or wherever.
Not
if your ride, like mine and my wife's Infinity, is keyless entry which is how the makers are going to defeat thieves. There's a "dumb" key in the fob to lock the glove box at the parking garage so the valet doesn't steal your heater.
BTW, just for nuthin I tried Hoa's suggestion and tried to start the car with the battery removed from the fob. NFG - no battery, no ride.
Re: Not
Hoa
Interesting. At least for 2015 Honda Accord and 2015 Acura RDX, if you push the Start button and the car can't read the ID from the fob because the fob has no battery, it displays "To start, hold remote near Start button." With the battery-less fob touching the button, the car starts just fine.
Re: Not
Way too complicated for me. If you lock the glove box and then have to give the fob to the valet, what good does locking the Glove box do?
Lock
The locking key gets removed from the fob. You keep the key, give the fob to the valet
Re: Not
A battery-less RFID tag uses an antenna to pick up RF and generates current to transmit the codes. (At least the kind of tags we used for a military project worked like this.)
Our '12 Murano has a special fat slot near the push button - if the battery in the remote is completely dead you push the whole remote into the slot to allow a start. I had to replace one battery after three years.
Re: Lock
Too new for me. I'm used to just dropping the reins on the round. A well trained mule will not wander off.
Not
In NYC. Your mule will be long gone when you get back. You then get to buy it back from the city stableman.
