Morris/Stickey style chair cushions
Alan Young
Alan Young
I am thinking about making a Morris/Stickley style chair-Mostly it is a request from a family member who wants it for a cabin that is "shared" by several siblings-so we are already in the danger zone when it comes to design ideas. I drew up a quick sketch- based on images from the web. My sketch has the seat and back cushions on wooden framework-I don't think I've ever seen springs incorporated into these types of chairs-one sibling has "done some research" and thinks the construction should incorporate springs for the seat- Is there any recommendation one way or the other for spring or non spring design?????
-Alan
Re: Morris/Stickey style chair cushions
Two Options
BTDBoth
First is a loose cushion:
This can be done as a onesy or 2-part cushion using a seat-board (3/4 ply covered in fabric)
Second is 2part with inner sprung seat and separate back:
I can say I much prefer the thicker seat with soft springs and webbing that are actually done as a removable unit.
Much more comfy.
Alan Young
Soft Springs--
Alan Young
Thanks Mark-Did you fabricate the second option with the soft springs? If so- What was your source for springs???
Nope
Upholstery is not my "thing". Tried it once as a shared "adult" class with Memsahib. May still have some of the tools.
Your best bet for sources is a smaller reupholstery guy in your neighborhood. Might also net you some leads for new commissions and/or repair work.
Re: Morris/Stickey style chair cushions *LINK*
Bob Lang
There are several ways to do it, and the originals varied over time and by which Stickley made the chair. Back cushions are loose with strips of material at the top corners to slip over the posts of the back assembly. If you want the chair to be comfortable, arch the horizontal back slats.
Seat cushions are mostly "loose" and the comfort will depend on both the construction of the cushion and what is below it supporting the cushion. That can range from wood slats to more involved upholstery and springs. Some had a box with 8-way tied coil springs that rested on cleats inside the chair frame as seen in the photo.
The smart way to do it, whatever option you choose is to make the seat removable, as mentioned above. That will save you from either finishing around the seat cushion or upholstering the cushion after the chair is finished.
I go into some detail about this in my book "Great Book of Shop Drawings for Craftsman Furniture" and in the blog post at the link.
Bob Lang
Craftsman Upholstery
Mark Hennebury
Rubber webbing.
It has a lot of advantages:
Provides good springy support.
its easy to vary the amount of support, by adding or removing straps.
Very Low profile.
Easy to install, press fit into slot.
Easy to replace.
Howard Pollack
Will you please tell us where those clips and webbing came from? Thanks.
-Howard
Mark Hennebury
It's been many years since i purchased the rubber webbing and clips, so i wouldn't know where to buy them now, but you should be able to find then pretty easy with a google search, that's where i got those pictures.
Mark Hennebury
Alan Young
Thanks for all the info..but
Alan Young
I will probably be passing on this piece- Too many cooks in the kitchen-I do however now have a desire to make one for my own use-Thanks evryone!
-Alan
