Pex
John in NM
I've done one structure with Pex, having always used either copper or cpvc previously.
As I understand it (and I may not) the industry standard with Pex is to use small lines running from a manifold. Pex in sizes under 3/8" is fairly bendable and easy to run.
However, when we were building our house, we would occasionally house sit at a house that had horrible water pressure/volume, in spite of having a booster pump set up and a large storage tank. I attributed this to long runs of small gauge Pex.
So when I installed it building our guest house, I used 3/4" and 1/2" as if it were regular pipe. Worked fine for pressure/volume, but the downside is that in these diameters it is not especially flexible - you can treat it as a flexible line still, but installation is not what I would call easy.
If there is a next time with Pex, I will treat it as I would rigid pipe. The trouble with that is that there will be more fittings to install, which increases cost and effort, and reduces Pex's strengths when it comes to frozen pipes (that may not be a concern in your area). I still think it would be cheaper and easier than soldered copper though.
As to tools, I bought a simple crimp tool that works with a pair of vise grips. Worked fine for a 1 job homeowner tool. For doing a large job or multiple jobs, I think it would quickly become annoyingly slow compared to the typical heavy ratcheting crimper. There are also crimpless connections, but I have no experience with those. If you can find a plumbing forum (seems like there are forums for everything), just lurking there for a little while would probably give you a good idea of all the pros and cons of the various connection systems.
Personally, I do like Pex in the larger sizes and using the crimped copper rings. I would probably use it again if I were building again, but I wouldn't depend on my ability to bend the stuff.
