Wine cabinet question
I need/want to make a cabinet to hold bottles of wine.
We don't buy cases or half cases - only single bottles (and not too many of those).
Making the carcass of the cabinet is not really a problem. I am going to make an open front cabinet with a wine glass "hutch" on top.
My question is how to make the "cubbyholes" for the wine bottles.
I was figuring on making a 5 x 5 or a 4 x 5 grid.
Something like this.
So anyway - I could make them out of plywood (not my favorite idea) - but that way I wouldn't have to worry about wood movement. I would prefer making them out of hardwood.
Needs to be about 12-13" deep. The individual cubbyholes need to be about 4" x 4".
Thoughts?
Re: Wine cabinet question
Keith Newton
The way I've done it is to use a dado on the TS with a sled, cutting half way across from the back on the horizontal, then half way across from the front on the vertical. I like two have the verticals a little narrower, to offset, or step back a little, which make it more forgiving on the alignment.
If i'm using plywood, I will put a new pice of 1/4" mdf on the sled to provide zero clearance on the sides of the blades to prevent splintering on the face. I also use a little stop that I bump against for the first cut, then set over to index each cut after that, which will give perfect spacing for the alignment.
If you get your dado set perfectly matched to the material thickness, you can edge the plywood before building, which is easier than applying those little pieces after.
John Veerkamp
make them out of hardwood about 5/16. Sliding mortices 1/2 the depth. This type of interlocking construction is often used in cardboard box dividers (Cases of wine). No glue needed so movement is not a problem. Small cleats fastened on the sides under each of the horizontal shelves should be all the support needed. The whole grid just slips in place with no fastening needed.
John McGaw
There are a zillion different ways to do it and, at that small size, I suspect that wood movement wouldn't be much of a hazard. I find that multiple dadoes in the verticals to hold the horizontals is easiest to cut. Even easier is skipping the full-sized horizontals and just using ribs to support the bottles. I did that in my double-sided roll-around wine rack which holds 64 bottles. I was a bit constrained by the idea of using only the pieces of wood that had been prepared for a maple blanket box that was never completed but it worked out well enough. The only added non-original wood was the white pine used for the tacked-in ribs.
Bruce, a MN Galoot
I built a wine cabinet for my son and his bride and if I can figure out how to add a pic from my iPad, I will post it. The wine bottle section is made of 1/2" BB plywood, from a less than stellar source. I cut and fit every thing, and it went together really well. A day or two later I set about to glue it up. I forget how many joints there are (30 or so), and I used Old Brown glue because of extended open time. By the time I glued it, everything had warped, even pieces only 4" wide. It was an absolute nightmare, maybe the worst glue-up I ever did. Thanks to a lot of time and all my clamps, it came out square and cleaned up well.
The takeaway? Be very careful of the fitment and use a glue with a really long open time. Patrick Edwards Old Brown glue gives 25-30 minutes.
Here's the wine cabinet
Bruce's iPad won't cooperate, so he sent the picture to me, and I'm posting a resized photo:
Purty thing.
Anything scheduled for door panels?
Gary Smyth
Beveled or leaded wavy glass might look nice.
Re: Anything scheduled for door panels?
Bruce, a MN Galoot
It doesn't show in the pic but there is tempered safety glass glass in the doors. There's a couple young'uns in the house.
