Robland sliding table attachment
Brian Freeh
I recently purchased a 1998 powermatic 66 with a sliding table attachment. After extensive research on the part number I came up short with a match. But what I did find is that it is what I believe to be a Robland sliding table attachment with a powermatic name tag. For the price I paid for the saw the attachment was an added bonus. I'm not sure that I have all of the parts. Is there anyway to purchase parts for this?
Re: Robland sliding table attachment
I use one
>1998 powermatic 66 with a sliding table attachment...
Brian,
I have the Robland sliding table attachment on my PM66, imported by Laguna. I purchased it used from a WoodCentralk benefit auction.
It came missing one part and Laguna was zero help - no one I talked to had heard of it so they basically told me it was obsolete, go away. When I finally got to an engineer who tried to help, the answer in the end was no parts were available. I wrote to Robland but got no response.
I was missing the crucial bracket that holds the crosscut fence in place and allows it to rotate. When I couldn't get one I machined a new one. (I started to machine it from aluminum but ended up making it from a block of Lignum Vitae. It has been working extremely well. I've crosscut some long plywood strips. The clamp is excellent.
Is the table installed? It was tricky to install and align. I had to ignore some instructions and fabricate some support elements. I have not yet finished solving the dust collection issues created by adding this since the original motor cover no longer fits.
I have the large sliding table in the picture and was missing part 34 in the diagram.
Do you have the manual with the diagrams and parts list?
What parts are you missing?
Re: I use one
Brian Freeh
YES !! that is exactly what I have. Where can I find a manual? My attachment says Powermatic ST-1. Basically I need everything but the table, guide rails, and part #34...lol I'm sure that I can rig up something that'll be fine but I would rather have the correct parts.
manual
I have no idea, I could not find it on the internet. I have a paper manual that I could xerox or scan (if I can remember where I put it!) I'm off to the TN symposium in a bit but I can check sometime next week. I'll send you an email but be sure to bug me if I forget! (unless you find one first)
The fence is an aluminum extrusion with a slot for the bracket. If you don't have it you could probably make a nice one from wood and one of those slotted rails made for hold-downs and jigs. I used a milling machine to make the part 34 bracket but it could probably be done with a drill press or lathe and a bandsaw.
Re: manual
Brian Freeh
That would be fantastic. I really appreciate it. I'll give you 1 1/2 weeks to get back to me and then the bugging will begin....lol
I'm a cabinetmaker by trade and always wanted my own shop. Last year I built a pole barn to have as my woodshop. Only problem is, I have to share it with my lawn equipment and some of the kids stuff. It was small sacrifice to get what I wanted.
Re: manual
Brian Freeh
Hey John, let me know what you want to do. I would really like to get a copy of that manual you have for the attachment.
Re: manual
Ok, an excellent bugging! This evening might be a good time for a scanning. I'll send by email.
Re: manual
I just sent an email to you with the scanned manual. I had to find it again - somehow when cleaning up I put it in a Safe Place then those brain cells must have been overwritten. Send an email if you need anything else.
