I tried to make peanut brittle out of nuts left over from Christmas. Have not made it in twenty years. Water and sugar in the Microwave. Blasted it hard. Made a terrible mess. It did not harden. Any suggestion on how to rescue it? (Its delicious, if you like peanut goo.)
I gained about 25 lbs doing this about 25 years ago. A delicious way to gain weight. I did use a recipe, sort of. I forgot the old one, so I looked on the Internet and then cobbled together about five different recipes.
Isn't that the way we build furniture? Sort of Greene and Chippendale Midcentury Modern put together with one Dominoe, a Kreg Screw, and a lap joint and belt sanded into submission.
...the hardness of a confection depends on how hot you got the sugar. The hotter you get it, the harder the treat when it cools. Sounds like you didn't get it hot enough. Maybe if you re-heat it to a higher temperature...
Just go to the nearest See's Candies store and buy out their stock of peanut brittle. There is no better. Anyplace. Except maybe Widman's chocolate covered potato chips in Grand Forks, ND. Well, I guess that's not peanut brittle, but they're really outstanding!
here is the best i have had, it doesn't stick to your teeth like most does , here it is now not all microwaves are the same wattage mine is 1100 watts and was a little to hot so next time i will do 80 percent heat, post back on how you did
use glass bown only one with handle would be nice or just pot holders
1 cup sugar
1/2 kero syrup cook on high 3:30 min
add 1 1/2 cups nuts any kind 3;00 min more
add 1 tsp butter and 1 tsp vanilla and 1:30 min more
take out and add 1 tsp baking soda stir in and spread thin on non stick pan let cool
