Domino Questions
With the smaller machine what is the deepest mortise than can be cut? Widest? Narrowest? Thinnest? thickest? Any reason one can't make their own tenons?
Domino Questions
Re: Domino Questions
Charlie belden
http://web.hypersurf.com/~charlie2/DOMINO/DOMINO_2.html
Yes, you CAN make your own. But festool's "dominoes" have grooves running down their length - to let air and any exess glue out - which is kinda handy. (Ever have a tight m&t open itself up from compressed trapped air - or do you clamp them shut and wait for the glue to dry?
Now that is what I was looking for
Thank you. Indeed a picture is worth a thousand words.
How much do bits cost?
DIY loose tenons
Dick Coers
I've made hundreds of feet of loose tenons. Instead of rounding the sides to exactly match the router bit profile, I chamfer then. Still locates the parts exactly the same, but also allows excess glue and air a path out.
Jesse Cloud
The smaller Domino makes mortises that are narrower and less deep than I would often use, but when I need more strength, its trivial to pop in a second domino, which makes a very strong joint.
I have made my own dominoes on occasion, but as I am too old to buy green bananas, I usually just buy them and use the time for more interesting woodworking.
If you are thinking about getting a domino, there is a small used market lately, as many have traded up to the larger machine and wish to sell their small one. You could post a free "Want to buy" add at www.festoolownersgroup.com
Re: Now that is what I was looking for
Charlie belden
The bits go from around $25 to $35 iirc. Check with woodcraft - they carry the domino and other festool tools
fredhargis
One point about the bits, there are after market bits available now made by CMT (maybe others I'm not aware of). Anyway, the CMT bits are typically a lot cheaper than the Festool brand, and I read somehwere (on the 'net so it must be true) that CMT makes the OEM bits that Festool uses. The small one takes bits up to 10mm wide, and cuts (I think) mortises up to 28mm deep.
William Duffield
Paul-Marcel St-Onje (Half-Inch Shy) answers all your Domino questions in four YouTube videos. I think the second one is the most pertinent, but it's been quite a while since I watched them.
https://www.youtube.com/watch?v=HLJaioykay4
https://www.youtube.com/watch?v=HP_-aIAQIYA
https://www.youtube.com/watch?v=Jfzp57WYrHs
https://www.youtube.com/watch?v=e_gc64MlYzE
TomD
I remember your bandwidth issues, but there is at least one guy who has a youtube video on how to make one. Basically the tool is simple, it is a router bit that pivots through an arc as it plunges into the material, You get the oval cut, and you get all the cutting done with the tip of the bit which reduces vibe. I think making a nice stationary model would be pretty easy.
More than meets the eye
Charlie belden
while a plunge router can be used to cut a round ends mortise - which id what the Domino does - there are several additional things the Domino Can do that would be tricky to do with a plunge router.
making a rounded end mortise in the side, top or end of a piece of wood isn't quite as difficult as cutting that mortise at a specific distance from a reference face and reference edge or end - and cut them on "left" parts as well as " right" parts (think mortises on table legs.
Making a series of mortises down the side of a part, registering each mortise after the first one off either end of a previous mortise eliminates the need for setting and resetting stops for the router approach
Then there's Domino's quick and easy ability to add side to side room to allow for wood movement.
Ever tried to balance a plunge router on the edge of a board and then route a mortise in that board's edge. Gets even trickier - in the end of a 6' board ....
The Domino is a revolutionary machine who is all too often seen as a very expensive biscuit cutter. it AIN'T - but you need to see it used and explained by someone who uses it - for all sorts of things.
Btw - the Domino bits have multiple facets on the end - not just a simple upcut or downcut spiral router bit.
I made a jig to route mortises. Then I bought the Trend M&T Jig. was thinking about the LEIGH FMT and saw the Domino at a WWing show. The Festool rep was pushing their track saws and routers and didn't know much about the Domino. I studied it a bit, cut some mortises with it and realized how quickly and easily and accrately it cut mortises. Bought one, played with it, studied it some more and realized it's advantages over a router based jig. This is a revolutionry woodwrking tool!
