Carving Board in use
Chili weather arrived which involved cutting up a pile of onions. The advantage of this board is the deep end provides a place for the chopped pieces to be temporarily stored before they go to the frying pan to be sweated. The size, 13", turned out about right for the intended purpose.
The paraffin treatment didn't soak deeply into the maple and some was stripped during the first use and rinse. (I probably burnished the maple during sanding which is desirable for oiling boards) It's now saturated with my traditional veggie oil treatment.
Re: Carving Board in use
I like it. Is 13 the ID, or OD?
Keith Newton
I may have to make a couple of those with some highly figured maple. It is thicker than I need, and wondering if you think being a little deeper on the far end would be desirable, since I have more to work with?
That is a beautiful knife too.
Re: I like it. Is 13 the ID, or OD?
The OD is 13". The deepest part is 7/8" and the bottom is 5/8" thick. The rim is 1". It doesn't weigh much (2 pounds) so I was not motivated to thin the bottom any more.
The 7/8" depth looked about right to my eye and it held 3 huge onions, chopped.
Clint Searl
Clint Searl
I'll argue against a dished design because the rim inhibits picking up the choppings with the flat of the knife or my preferred 6" putty/drywall knife.
