Need a little help
Need a little help
Need a little help
Marty
I have gotten myself into another Antique restoration project,(seems I can not say no to the women at Church). I have a door that someone fell into and broke the glass,three of the four panels (4"X25") I am struggling with getting the old glass putty out. Must be as old as the item it self,never replaced. I am chipping it out but it has taken me three days,Is there a faster way to remove the old putty(very hard)? Read on a web site that it could be soaked in water or alcohol over night. I could try this but affraid it might make the panels swell and be misshaped(warped) Any help????
Re: Need a little help
John McGaw
Traditional glazier's putty was a mixture of linseed oil and whiting. In any case the key is the binding linseed oil which is not soluble in either water or alcohol. It is soluble in regular old paint thinner though and that may be the key to softening it enough to get it out. The other commonly-used removal technique is heat but if the stuff you are facing is sufficiently fossilized then that may not be an option.
Did you try cutting it out with a small rotary blade on a dremel. Or a multitool? I have used the Fein Multitool for many difficult things but I have not tried it on glazing putty.
lead
Was lead ever used in the "old days"? If so be careful atomizing the glaze.
Marty
Thank y"all for the info. I will try the paint thinner. I do not have a multi tool,nor a rotary tool. I am thinking neither would work as I am dealing with"ribs" that are 4" apart and a very awkward half round door frame.
Re: lead
Marty
Mr Bill, I can see no lead. I know you cannot see lead,but I do see a fiberious material,( very very small flakes)like fiberglass binding it together.
Re: lead
Howard Acheson
Big Box stores carry lead testing kits. They are cheap and work using when dealing with old finishes and various other building things.
That sounds like asbestos!
Dick Coers
And that is a possibility. You should do some research, but in a quick look, it is a chance.
Do you mean in the glass?
John in NM
As in leaded glass? Highly unlikely for window glass at any time since lead is not a normal component of glass but is added to increase the refractive index.
Never heard of it in glazing putty either, though if the woodwork is older than the 1970's it could well be present in the paint covering the putty.
not that kind of lead
White lead, chemists would call it white lead dioxide, was once mixed with other stuff and used as caulk and sealant. I know this use continued into the 1970's. I don't know if it was used as window glaze but I think it could have been. Maybe one of our "Old Timers" would know.
Question
If not lead dioxide what was the white stuff used in glaze in 1920, or 1950? Glazing would seem a natural use for white lead dioxide. Mold won't attack it so it weathers forever.
Re: Question
Dick Coers
Calcium carbonate (chalk), or dolomite
Yup...
John in NM
Just calcium carbonate and linseed oil.... I don't expect lead would be found in glazing compound unless incidental and in trace quantities. Carbonates are relatively inert and very cheap due to being plentiful.
Re: Yup...
R. Payne
I've got a book of old recipes (early 1900s) that includes a couple for glazing compound, one of these does call for white lead in addition to the whiting and linseed oil. Lead compounds are "drying agents" for linseed oil.
I'd test before going further.
The fibers may be asbestos. Or horse hair. Or a number of different fibers depending on what was available at the time.
ron
Interesting...
John in NM
That is certainly a good data point if the piece is truly old.
The stuff I remember was just regular DAP glazing putty, no driers in it at all - took a week to skin over as I remember, and months to fully harden.
John McGaw
I would stay away from any sort of power tool on an antique -- too easy to do damage which would not be easy to undo.
Re: Interesting...
Marty
Thank y'all for all of the input's. I have removed 90% of the glazing using Mineral Spirits (Paint Thiner) as suggested. I did use a paper mask and goggles, just in case. Now it's off to the glass shop to get three replacements and put it all back together. If I knew how I would some pictures up to show y'all, thanks again for all of the input.
Re: not that kind of lead
When I worked in a motor repair shop, I have used quite a lot of White lead and Glycerine mixed to seal the leads in the junction box of TEFC Gas pump motors. It was the accepted material in the late 50's & early 60's (don't know after that) for this as it was both fireproof, solvent resistant and electrical non-conductive. It hardens quite quickly and is pretty tough after curing. However, I have never heard of it being used as "window" or any other "caulking".
