Refresh My Memory on Single Bed Size
John Foster
Hello All
My eldest granddaughter is ready to move into a bed. I will be converting a so called mini crib which is 39' on the long sides into the headboard and footboard of the bed.
The leg centres of the head and foot boards are about 39 5/8" . with 3/4' stock for the side rails, I will be a bit under 39" inside width. We currently have no single beds in the house, what do mattresses run for width? do they tend to be over or under the nominal 39" x 75" size?
Re: Refresh My Memory on Single Bed Size
suggest beefier rails
If the mattress is suspended from the side rails make them 1". I had a 13/16" cherry rail split while someone played on bed jumping up and down.
I have built several single beds. I just went to mattress store, measured mattress and made frame 1" bigger. You want some gap so the sheets can be easily tucked.
Re: suggest beefier rails
John McGaw
Yes, be sure to leave enough gap, especially since the next mattress might be just a bit oversize. I built my queen-sized solid cherry bed (rails are 1.5"X6") just a hair oversize and found that the mattress was entirely too tight between the head and foot boards making sheet changes a real workout.
Bill is right. The mattress is 39 by 75". Allow and inch or two if you can. Use a 1/4" round over on the edges of the rails. And beefier rails would be better. If you don't have any heavier stock you can laminate a piece along the inside with notches in it to position the slats. If that piece is maybe half the width of the rails it will hold the mattress higher and add some strength. You can also make a support to go under the center. I did that on a king sized bed.
Dick Coers
I've never seen an oversize mattress, always a bit undersized. I've made solid wood rails, and plywood as well. The plywood rails are made like I beams with solid wood (wider than plywood on top and bottom). You get a really strong rail, with less weight. If you make a fairly wide rail, I plan on at least 3/4" clearance per side.
John Foster
So if my existing headboards have holes on centre in the legs to fasten the side rails, what are the best ideas to widen the side rails? Vertical angle iron is the first thing that comes to mind; one leg fastened with the holes in the leg, and the second leg fastened to the inside face of the side rail. I think appearance wise it would look okay if the outside face of the side rail was flush with the outside of the square leg. That would give me a bit more width to work with as far as rail thickness and play room for the mattress.
Consider wood movement
Dick Coers
When fastening steel to wood, remember the wood moves across the grain. Use oversized holes towards one end. I've also used aluminum angle, I think it looks nicer. You can also let the angle into the rail if you need more depth.
Howard Acheson
The general way to answer your question is to measure a mattress that you plan to use or to buy the mattress before you begin.
Bruce, a MN Galoot
Not sure about how beefy the rails need to be. I made a set of twin beds for my kids, maybe 30 years ago or so, 1 X 6" oak rails, mortised and bolted into the headboards and footboards, and I've never had a problem with them. I'm a fairly beefy guy and did a fair amount of rough-housing with both kids on the beds until they were in junior high. Never a squeak from the bed.
There is a 3/4" X 1-1/4" piece of oak let into a dado a couple inches down, both screwed and glued in place, that serves as a rest for the plywood base. The plywood then is screwed to that stop.
They must still be okay because we refinished one, stained it and our granddaughter now uses it.
my failure was the bed was supported with the cleat at the bottom of the mortise and the bottom 1 1/2(about)" of the rail split off.
