A video piqued my interest in wet sanding very thin green turnings on the lathe. I know some think GFCI's are terrible, but I like using them outdoors and near water. My Powermatic 4224 lathe is on a 240V 20A breaker and plugs in at the wall using a 240V 15A NEMA 6-15 plug (if my memory from this morning is correct). I have installed a number of 120V duplex GFCI outlets, does anyone know if there is a 240V GFCI outlet? The price I was given today for a snap-in Square D 240V 20A GFCI breaker was $160. Thanks.
Yikes, That is kinda pricy. First, I would check on ebay, because you can sometimes find really good prices there.
Also, over the years, I've had to replace outside gfi receptacles much too often, especially when they are located out in a really exposed area. I've found that another way to end that, is to put the gfi receptacle indoors, ahead of the one outside, but downstream on the same circuit. I think it can protect others behind it, if you wire it right. I'm only mentioning this, wondering if you could put one on each leg of a 240 vac leg, and achieve that same protection? I don't know, just thinking out of the box.
I believe this lathe has a VFD and if so, there are many reports of VFD loads tripping GFCIs. Apparently the harmonics generated by the VFD are the cause.
I have to run my Oneway 1224 on a non GFCI circuit. It is 120 VAC. When I built my new shop, I plugged the lathe into a GFCI protected circuit and it tripped the breaker as soon as I turned the lathe on.
Don, this question came up recently in a different thread. After a whole bunch of searching and comments, I believe it boiled down to the nubbin that a 240v gfci circuit has to be established at the service panel with a breaker rather than at a receptacle where you plug in your load; could not even find such a receptacle at any on-line supply house. Seems the primary use for such a circuit is hot tubs, pool heaters, and jacuzzi-type bath tubs.
Ditto on the VFD comments. When I moved my Stubby out of the basement to the garage I had to run a new 240 line. When I bumped against the code for garage circuits to be GFCIs, my supply guy (knowing I'm a woodworker) wisely asked what the new circuit was for. When I told him "a 3hp VFD lathe", he told me to forget the GFCI as the drive would trip the breaker.
Wow, comments about VFD and GFCI just prevented my wasting $160. Thanks everyone. Now I have to ask about safely wet sanding on the lathe without FFCI protection. Off to the Turning Forum.
Fantastic! But didn't you hear? 10% of any money we save through WoodCentral discussions is supposed to be donated to help run the web site! :-) Just kidding! (I'm sure I would owe them hundreds of $$$)
The store does have some great hats and things. I can highly recommend the tee shirts.
PS, I have no stake in or connection to WC (except through my WiFi router)
