Hardwood Flooring
Hardwood Flooring
Hardwood Flooring
Yonak
First, please forgive my ignorance.
There's much discussion about wood movement and designing to accommodate it as inevitable. I'm just wondering how it's done in wood floors.
The tools and systems I see to install hardwood floors nail the boards as tight together as possible. What keeps the floors from buckling ? It seems to me that the forces involved would be stronger than wood being held simply by nail heads.
Re: Hardwood Flooring
Much to know here. The answer is very complex and simple at the same time. You can get more information than you ever wanted to know by searching NOFMA (National Oak Flooring Manufacturers Association.) Or some such, that will get you close. They have a PDF that will break it down.
Basically, Wood expands about 10% with a change in moisture content from 100% to 0%. That never happens in real life. Wood arrives at an MC of about 1/5 the relative humidity. So it swells and shrinks as the humidity changes. If you control the humidity inside your house it probably never swings over about 40% so the wood movement is much less than than the max. It probably moves about 1 or 2%. In a room that is a 100 inches wide it could shrink and inch or two. The boards are often 2 1/4" wide, meaning there are about fifty of them across the room. So you divide the total movement by the fifty.
The first instruction in the PDF is to condition the space and have it in the "lived in" conditions and then bring the wood into the space and let it sit uninstalled until it acclimates to the conditions. Then nail it into place. Each board is fastened along one edge only and the other edge is held in place by the tongue on the adjacent piece. If a 2 1/4" board only shrinks 1 or 2 percent, the cracks are not very noticeable and "acceptable".
As a Home Inspector I have seen what happens when the house is not kept conditioned or they violate the rules:
Builders in a hurry may not dry the house thoroughly and bring in flooring that is kiln dried. The flooring swells and if nailed adequately, the boards cannot swell and crush each other, then it drys and shrinks, opening up objectionable cracks.
Just the other day an acquaintance bought a house at foreclosure that had been allowed to sit and become entirely too wet. The oak flooring had swelled and buckled up off the floor six inches or more.
In another case there was spring under the house and the oak flooring swelled to the point it that it pushed the walls apart, bursting the room right down the middle over the center-line beam. (Two sets of joists lapped on the beam)
ON and ON. Look up "rafting" or "panelization". Follow the effects of changing from diagonal wood sheeting to plywood to OSB.
Then start to figure out the effect of the finish on the upper surface.
Thanks, Barry.
