Carving Board
Carving Board
Carving Board
PIC 1
Someone gave us a larger (15 1/2") version of this board for a wedding present. The large size is good for turkey carving and other large feasts. But we also found it useful for meal preparation. For example, when slicing pounds of onions for onion soup the bowl shape of this board contains the slices where a flat board does not. The problem is the large board is too large for much of our needs. So I set about to make a 13" version for more typical carving and slicing.
The way to make these is on a lathe if you have one big enough. I didn't. I would have liked to have found an easier way to get to the end but I didn't come up with anything better. Any suggestions?
PIC 2
A blank was glued up and a circle of holes drilled to remove some waste. Then I free handed a cut with the round nosed cutter to define the outer edge. Then more holes were drilled to remove the interior waste. The gouge chopped out what the drill didn't get.
PIC 3
Next the blank was mounted in a sled and the bottom of the bowl mowed off level with a 1/2" end mill. Finally the blank was mounted in the sled at an angle and the rim of the piece was tapered from 7/8" deep to 1/4" deep on the shallow end.
A cleat under the shallow end makes the board level in use.
Normally I treat a cutting board with veggie oil. But ,the cherry board will be a gift and oil makes cherry dark. Too look better for presentation I brushed very hot paraffin wax on the board, leveled the wax with a heat gun and wiped off the excess while the wax was still hot. As the wax wears off maintenance will be with veggie oil.
The overall sizes are 13" diameter, 1 1/2" overall thickness and 7/8" deep.
Re: Carving Board
Suggestions.....
That is beautiful and I am sure they will appreciate it. BUT, as usual I have a suggestion or two.
I have a board I made to fit beside my kitchen sink and act as a cutting board and drain board. It works well except the raised edges on it are bothersome. They interfere with my limited knife skills. I suggest the rim on your board will be in the way too, more so as the board gets smaller and deeper.
I made a bunch of boards over the years (rectangular) that were dished out a little in the center on both sides. Maybe a 1/4 to 3/8". This left the corners proud to act as feet. The juices tended to stay toward the center, but the curvature of the board was so gentle it matched the shape of my chefs knife. If juice or water got under the board, the concave shape prevented it developing the suction that might hold the board down to the counter. The board without the rim is much more pleasant to use.
You are right, that would have been a fairly trivial job with a big enough lathe. Another way would be to hang your router from the ceiling on a chain or cable with a turn buckle in it. The router swings like a pendulum and will cut out the dish out the piece on an arc. The turn buckle gives you some adjustment. The length of the chain or cable determines the arc/dish. Swing the router in every direction to cut away the wood and finish with a ROS.
Re: Carving Board
Re: Carving Board
Keith Newton
Yep, The lathe would be the way to go. Does your lathe have threads for a outboard faceplate? It shouldn't be too hard to make a floor stand for your tool rest. Then, you can make a wedge shaped sub-faceplate, to turn the hollow in at a tilt, leaving the bottom flat, without needing to add the cleat.
If you did your cutting from the high side, then the lip ought to be out of the way as Barry describes.
Re: Carving Board
Re: Carving Board
I love wooden cutting boards over plastic. Your method of applying paraffin is the way I often apply beeswax.
BTW, if someone mentions it is dangerous to use a wooden board for raw meat, they might find this interesting:
http://lifehacker.com/5847591/10-stubborn-food-myths-that-just-wont-die
The research cited indicates that wood may actually be safer than plastic.
Re: Carving Board
disagree
" I suggest the rim on your board will be in the way too, more so as the board gets smaller and deeper. "
This board is not a theoretical trial of some experimental design. I have been using its large twin for 50 years.
Re: Carving Board
generations of experience
"BTW, if someone mentions it is dangerous to use a wooden board for raw meat,"
If someone frets I will point out that butcher blocks were used for raw meat from the time knives were invented until recent times when it has become fashionable to fret over any perceived risk. It is not an issue I intend to begin worrying about until my immune system fails.
Re: Carving Board
Re: generations of experience
Chuck Kettler
Amen to that Bill!!!
Re: Carving Board
Butcher Shop in Italy
Note the well used wood butcher block. This is what butcher shops looked like in my youth.
Re: Carving Board
Ron Pemberton
Me too.
Re: Carving Board
Re: Carving Board
Jay Lombardo
For the first 21 years of my life we lived upstairs of a wonderful old German butcher shop in Chicago. Saturdays would have 12-15 butchers working front counters and back room. EVERTHING was cut on huge wooden butcher blocks at least 2 ft thick and the floor was covered in beautiful clean sawdust. They kept that place spotless and with all the cleaning some of those blocks were dished by 4 to 6 in. Now the open 55 gal drums of bone and fat that was stored out back for the rendering house pickup once a week, and the well fed critters back there, that's a different story! You could saddle some of those rats, but that was life on the west side in the 50's.great memories
Re: Carving Board
Sure agree Bill, I remember in the 50's I had an Ulcer as a teenager. The Doctor prescribed that I drink/eat heavy cream every day and eat raw eggs. The theory was that this would coat my stomach. So I would take an egg from my aunts hen house, poke a hole in one end, put my finger over the hole then turn it over and poke a hole in the other end. Then I would suck the egg out. Many of these were still warm from exiting the chicken rear! I never have worried about salmonella, sure none would survive in my system.
Among other things my father was a butcher, we had a cutting block that was about 3' square, dished in the center probably 4~6". It ended up in the early 50's as a stand for a 50 gallon barrel holding heating oil when we piped it into the oil stove in our home. Local store had one very similar ~ long before food inspectors invaded. Can't say I ever heard of anyone becoming ill from eating food from the store!
Of course, me and all of my friends swam in the local creeks, sometimes when the cattle waded upstream we had to leave the creek to let the stuff float by! I don't think I ever swam without swallowing some of the water, can't say anyone ever became ill from that either.
Personally I think the "sanitary" lifestyle people are trying to live now prevents the body from developing immunity to anything. Seems like all the children I see are a lot more unhealthy than my generation!
Re: Carving Board
Right on Larry
Maybe it's an Indiana thing since I'm originally from BRownstown. I firmly believe that my not being that clean growing up has kept me healthier than most of my friends. I would get a cut rub dirt in it to make it stop bleading. Dropped a fork on the ground, just pick it up and wipe in on your jeans and keep on eating. There are many more examples but it would probably make todays people sick to hear it so I won't go there.
Re: Carving Board
Barry Mabery
I have an oval shaped board with only a blood groove. I believe it was a gift from the Bally Block salesman to my father who was a purchasing agent for Swift & Co. He bought a lot of butcher blocks for the company. They had, as I recall, a life expectancy of less than two years - not from wear - but because they were hosed down at the end of each 8 hour shift with live steam. The steam treatment wasn't kind to the adhesive or the maple.
But they recycled the used blocks by cutting them into 1"x strips and using them in the bacon or ham smoke ovens. The USDA approved replacement butcher blocks, made of cast polyethylene, neither lasted as long nor could they be recycled. And the cutters, choppers and butchers who used them hated the plastic and wanted to return to the maple blocks.
Re: Carving Board
It's A Different World, Guys
from when us dirt-eaters were growing up. With our population having more that tripled in the intervening years, food production, preparation, and delivery demands have pushed the industry far beyond the practices our fathers and grandfathers used. The opportunities for the spread of pathogens has multiplied many times over and we, as consumers, are routinely exposed to "bugs" that our parents didn't even know about when they were kids.
Easy example: Upwards of 95+% of raw chicken carries the campylobacter bacteria that can and does cause serious illness. That's why you must cook chicken to 165° to make it safe to eat. That's why you must not prepare your salad or other foods eaten raw on a cutting board that's been used with raw chicken.
My paternal grandfather was a butcher. His teaching on "chop meat" was simple: Don't eat ground meat that you haven't ground yourself from cuts that were first washed in clean water. He also refused to eat a hot dog, regardless of who made it.
My father had a practice of buying a piece of fruit or a bag of grapes as he walked home from his office in NY City. He'd often start eating his purchase before he got home and washed the items. He died from a listeria infection that started with a stomach upset and turned into encephalitis when the bug migrated to his spinal column and then into his brain. It's a slow and nasty way to die as the bug eats away your brain, and there's no cure.
My point? Use different cutting boards for each class of foods, and do what you can to sanitize them between uses. Grandfather followed the old method of scrubbing his wood butcher blocks with salt as the chlorides served to knock down most any pathogen. Plastic boards (as are mine) can be sanitized with chlorine bleach and then rinsed clean between uses.
Re: Carving Board
It's not the chlorides...
John in NM
Salt is weakly antiseptic due to osmotic pressure, basically the same mechanism by which canning works to preserve. The fact that it is a chloride is merely coincidental.
I believe that chlorine beach disinfects by oxidizing the bugs - the hypochlorite anion is quite reactive and gives up it's oxygen readily (leaving you with salt water and dead bugs). However that is getting into the areas of chemistry where I am less than well grounded, so I may be wrong about the mechanism.
Re: Carving Board
Whatever
nobody got (or gets) sick from the cutting boards.
[They may have issues with my chili, but that's only after being warned.]
Re: Carving Board
Ok Socrates...
John in NM
I'll leave you to your "whatever" world and stick to one where the details do, on occasion, make a difference :D
Re: Carving Board
Nothing Philosophical About It
Just time-tested method.
My family owned a small hotel/spa ("fat farm" in 60's jargon) on the Jersey shore. Kitchen regimen, per local health code, was that all cutting boards were to be scrubbed down with warm water and course ground salt after each meal, and the final cleaning was allowed to sit until the following morning when they were rinsed off and oiled in prep for the day's use. Different boards were designated for meat, veg, and fish/seafood.
Whether it was the salt, the scrubbing, or "whatever", the food surfaces were clean.
Re: Carving Board
Re: Carving Board
Jesse Cloud
When I took cooking classes, we were taught to clean the cutting board with soap, but after a few uses, to rub salt and water on the board and scrape the board with the blunt end of a cleaver. Basically peeled a thin layer of "skin" off the board.
I just assumed the salt functioned as an abrasive.
"Whatever", it did its job, the board looked like new after that treatment, though a bit thinner. ;)
Re: Carving Board
salt kills critters
Recall nothing grows on salted meat.
Re: Carving Board
Correct, not philosophy at all....
John in NM
My sarcasm was more concerned with the practice of rhetoric than philosophy :D
Re: Carving Board
Then
"May your house be safe from tigers"
Re: Carving Board
A nice thought Mark
John in NM
Hat's off to you :D
