Well,not exactly explosive but it does burst into flame. I was sweeping up some debris under my bandsaw and the dustpan was full of small chunks of hardwood as well as plenty of fine wood powder. I thought to feed the chunks to my wood furnace so opened the door and threw them in. The dust,being very light, filled the air between me and the fire and a flash of flame burst out at me singing some facial hair. I was surprised but will definitely never do anything like that again.---Jack
Furniture factory dust collection systems have sensors that detect the propagation of a dust explosion through the ducts and isolate the explosion with gates and suppression. Flour mills suffer the same problem. It was not long ago the news reported one that blew up.
One of our customers worked out of his garage with a wood stove. He looked a bit worse for wear one day. He reported that he was handling some assembly that hit something overhead dislodging a cloud of wood dust. The dust was ignited by the wood stove and the explosion blew him out the garage door.
Pretty much any fine dust of a combustible material is explosive. Seems like I remember a mythbusters episode (or maybe it was a youtube video) that produced a pretty impressive explosion using coffee creamer!
Get the right ratio of fuel and air, then an ignition source, BOOM! Throw a match on just a pile of dust, the flame may actually go out. Suspend the dust in the air to get a fuel/air ratio and you have a bomb. I'm constantly annoyed with movie and TV stunts. They so often show the gasoline explode, only when the match, or flare, touches the liquid. Let that gasoline sit as long as the villain usually does, and you gets lots of vapor. Just strike a match in the air and really sees what happens!
Here in corn country grain dust can make a powerful explosion. A single spark in a grain dust filled silo can go off like a bomb. Hats off to farmers....it can be a dangerous job!
I first learned about this nearly 70 years ago. My uncle had sanded the floors in his house and was burning the resulting wood dust. My cousin grabbed a handful of the dust and tossed it into the air over the fire creating a very satisfying fireball and a nice "whooomp". We amused ourselves with fireballs for several hours that afternoon.
In 1998 a grain dust explosion in an elevator near Wichita Kansas could be heard and felt for several miles. I know it rattled windows at least 15 miles away. Several people were killed and some were trapped for several hours on top of the elevator. I have included a link to a slideshow about the elevator explosion but you will have to wait through a 15 second commercial before you can get to the slideshow.
My office used to be located right next door to the regional OSHA folks. I was over one day inquiring about grain dust because of a local elevator explosion. They explained there is NO SAFE LEVEL of dust and that used to drive the grain elevator operators a little nuts. But then they didn't like explosions, either.
I learned that as a kid, having good fun throwing handfuls of coal dust into the furnace. That was until my fun escalated with a whole shovelful of coal dust. The resulting ball of fire singed my hair and eyebrows and pert near set the house on fire.
A friend in special forces in nam told me demolition stories with two stages - first, a little explosion to fill a building with a combustible powder; second, a powerful explosion from igniting the powder. He said the second explosion was what took down the building.
Mythbusters did an episode on movie stunts and one of them was the leaking car gas tank and the hero drops a match on the leak trail and the flame follows the car and blows it up.
The result of their test it was impossible to ignite the gasoline trail on the pavement with matches or anything else let alone have it follow the car.
This was done in open air with a limited amount of spillage so there wasn't the vapor risk that would be present in a building.
>...it was impossible to ignite the gasoline trail on
>the pavement with matches or anything...
I suspect the conditions have a everything to do with it. I know of one case which although I did not see it with my own eyes, was told to me by someone who said he was there and whom I had no reason to disbelieve. In this case, the flame was reported to have followed the gasoline vapors from where a guy had doused a brush pile with a can of gasoline.
And while I never tried it with gasoline (thankfully, I suspect) I we used to have great fun in my pyro days with alcohol trails. I can testify that even a long (ethanol) trail on concrete can certainly be ignited, at least indoors. (This was in a safe place, kids, don't try this at home in the shop!) We made many long and artistic trails with squirt bottles, drawing pictures, writing words, geometric patterns, "kinetic art." Some of these were probably 100s of feet long with several people working at once. I wish I had a camera then.
I suspect the myth guys would have success if they used the less volatile alcohol, indoors, and on slick concrete.
I did a quick search of Mythbusters episodes. I think you may be referencing one of two different Mythbusters.
One episode dealt with whether a trail of gas could be ignited by a cigarette butt (improbable as the ignition temperature of gasoline, 500-540 degrees, is at or above the temperature, 450-500 degrees, at which a cigarette burns). A lighter would easily ignite a trail of gasoline
The other episode dealt with whether a trail of gasoline, once ignited, could catch up with a moving car (a car would easily outrun the burning trail of gas).
Worked as an electrician for over 40 years, did a lot of "explosion proof" installations. Rigid pipe, vapor seal-offs, all cast fittings, threaded covers, etc. We did a lot of chemical facilities, gas stations, all the usual suspects, but the people who were the most paranoid of explosion (because of a previous incident) was a candy plant that produced marshmallows, couldn't see across the room with the dust in the air. Everything we installed was explosion proof.
Jack I had the same thing happen when burning my shavings. I usually clean out the dust collector first and then put the shavings on top and light all of that. I forgot so after I lit the shavings I went into the shop and got the dust collector bag. As I threw it on the fire there was a sort of explosion with flames going all around me and singed some hair on my arm. This happened so quick it was scary.
I am always worried about fire and having at the time a small shop with the dust collector inside I had a fireman friend come over to talk to me about fire and especially dust explosions. He said exactly what is mentioned below. It has to be the right ratio and usually takes a lot of dust to actually have an explosion. You can however get a pretty quick flame burst if you had an ignition source near the dust collector and the bag were to bust open or pop off the metal housing. After that I made double sure to check the clamps when I replace the bag. In my new shop the dust collector is in a seperate room outside so I think I've reduce that problem tremendously.
John Jordan's episode reminded when I was young we were taking shotgun shells apart and burning the gunpoweder. Throw a match in and you get a nice bright hot flame that sort of spreads quickly. We ran out but I knew my dad had some Black gunpowder. we got that. by then it had gotten windy so we dug about a 6" hole and filled the bottom with gunpowder. I thought it would burn faster so I made a 1 foot trail of powder. We covered the match with our hands to keep it from going out and stuck it in the trail of powder. Well on TV when they do that the trail takes several seconds to reach the barrel of powder. Our trail took about the blink of an eye if that long. We didn't have time to do anything but close our eyes. burned off half my hair, my eye brows, eye lashes and made our face black. Fortuntely that's all the damage that was done and we easily washed our faces. Couldn't hide that burned hair from my Mother however.
It's a wonder some of us are alive today. Most of the math/electronics/physics/chemistry guys I knew from the 60s either excelled at college and career or spent time in jail from manufacturing drugs.
Some friends blew up the chemistry lab once. We had contests to see who could develop the fastest-burning gunpowder formula from basic chemicals. I still have a scar on one finger from shrapnel from a device malfunction when I was about 12. One episode sent my brother to the hospital. I think we all watched too much Wild Wild West.
A friend of mine liked to play with home-made nitroglycerin and big home-made liquid fuel rocket engines while I stuck to milder things. Like making grenades from glass bottles and a potassium nitrate wick to throw over the hill by the river - if you threw too soon it would just break on the rocks and go out. If you threw too late it would take your hand off. I still have a brass black power canon in the barn if you want it.
Some of things we did 40 years ago would bring a visit from the government today.
I seem to remember the salt peter, sulfur, and charcoal thing. I also seem to remember the kid next door adding some kind of metalic powder, I think aluminum or some form of mercury. I do remember the fire department, the ambulance, and his surviving the 'speriment.
My high school shop teacher demonstrated for us. Our shop was the original school gym and had 'finishing rooms', the original dressing rooms, in opposite corners of the huge room. He gathered us together and made the speech: I know some of you smoke, but don't ever do it here! With that he threw a small handful of sanding dust in the air while lighting his cigarette lighter. quite an impressive poof! of flame.
He told us to imagine that in a finishing room full of alcohol, thinner, sanding dust etc. very effective!
Hmm... did you live next to me? or my buddy Jules?
Powdered aluminum is a wonderful substance for making things bright and hot.
The only mercury thing I know of is mercury fulminate. For years there was a streak down the side of the high school from a mercury fulminate episode episode involving an open chemistry lab window sill and a puff of air at the wrong time. You'd have to ask Jules or PaulP about that. I was in calculus class at the time.
In my advancing years my powdered aluminum gets glued into grooves in wood and the only thing I blow up is helium balloons for the kids. And maybe talk a little funny in the process.
ps. Not all dust is explosive, but sawdust can be. Explosive dusts must contain organics (e.g. limestone dust is not explosive but coal dust can be). Moisture content of the dust is critical, as are dust concentration, particle size, oxygen concentration, and ignition source energy. Housekeeping is very important, as many dust explosions are secondary events triggered by the primary dust disturbing event (i.e. something shakes the building, then all the dust lying about the place becomes airborne, and then BOOM).
In my earlier work life we did many experiments with garbage bags filled with various concentrations of flammable materials at different oxygen concentrations :-) as no published data existed for our process conditions.
Yep, I live in North Dakota where the winters can get brutally cold and can't just leave windows and doors open during those months. My shop is detached from our house and I have a hanging forced air wood stove that I built quite a few years ago. One day when I was working out in the shop the air was getting pretty thick with dust, breathing the dust and constantly having to wear a dust mask was getting to me, watching it settle on everything, and afraid of blowing the place up, I decided that it was time to do something about it, NOW ! So I bought a dust collector, and an air filtration machine that I hang from the ceiling. I still wear the dust mask, but not nearly as much now, and the shop stays cleaner. It's all made a big difference, and gives me some piece of mind. It was well worth it to me.
