finding thicker wood
Simon St.Laurent - Dryden, NY
I'm enjoying the latest from Christopher Schwarz, the Anarchist's Design Book, and it has me thinking about my lack of local wood purchasing options. Around here (beyond Lowe's and Home Depot), I can find 4/4 wood in a 30-minute drive and 8/4 wood in a 60-minute drive. Beyond that, it's at least two hours to northern PA.
Schwarz's staked furniture wants thicker tops:
"I wouldn’t want to make a piece of staked furniture with a platform that
is less than 1-1/2" thick. Once you get to 4" thick, you can make almost
anything with staked construction. (33)"
For the sawbench, not a giant project, he writes:
"Elm would be the historical choice, but good luck finding that. Poplar or pine are readily available and suitable.
You want the top to be thick – about 2-1/2" to 3" is sufficient. A thick top gives you a lot of joinery surface for the conical mortise and tenon – and that’s how you can get away without having any stretchers between the legs. The top should be about 7" to 9" wide x 17" long. But don't worry if your dimensions are a little bigger or smaller."
I'm not looking for elm, though I'd be happy to stumble on some. (I have a bit of 4/4.) But where might I find 10/4 or 12/4 poplar? Even pine in those thicknesses is unusual.
This almost seems like a case where mail order could work better than the usual boards - thicker stuff, but not gigantic. (At least at first.)
