OT Failing interior paint question
The house I am working on to flip has a detached garage. I am sprucing it up to sell it along with the house. It has sat empty and unheated for several years. The drywall is beat up. While making patches I have discovered the paint will come off with very little abrasion. You can scrape it with a coin gently and remove the paint right to the paper on the drywall. I have scraped the paint back where I am making patches, but the question is what to do with the rest of it? Is there some product that will re-adhere the old paint to the wall?
Re: OT Failing interior paint question
Getting through the paint?
Dick Coers
Won't you need to get below the paint to adhere it to the drywall? I'd guess it went years with nothing on the bare drywall, and oxidation and maybe dirt kept the paint from grabbing. I guess I would just try shellac, or a shellac based primer. I'd go with some really thinned out shellac to try and get through the paint a little.
Re: Did you ask Sherwin-Williams ?
ChuckinND
Or any other reputable paint store ?
Clint Searl
Clint Searl
I'd dry-scrub it with a stiff bristled floor brush, followed by a wet rag wipe down, then roll on a new coat of latex acrylic.
walta
I wonder if the gypsum absorbed moisture while the heat was off.
Is the paper is separating from the gypsum? Or is paint separating between 2 layers of paint.
Walta
Jason Roehl in Lafayette, IN
There is such a product!
It's called "unicorn poop".
Sorry, I couldn't resist... :D
I'd grab an ROS, load it with some 80 grit, and sand those walls down. Just put in the elbow grease. Even if sections of paint seem to remain adhered, when you go to roll on a primer/sealer, they may lift when the primer wets them, so you may need to do 2 coats of primer.
My experience has been that drywall and interior paint don't do so well in unconditioned space in climates where the summers are warm and humid, while the winters are cold and dry.
Jason
don stephan
I can't imagine any product soaking through the layer(s) of dry paint and adhering the dry paint to the paper surface of the drywall.
Bill Howatt
Me too! I think this is another case of, "the hard way, is the easy way".
I can see trying a shortcut only to have it fail in this situation.
Bill
Thanks, all, what a shame....
I was afraid here was no magic answer. I just don't know if I have the energy to scrap and sand the whole thing. The down stairs is 32 by 24 and up stairs is 14 by 32'. Ouch! that's a lot of work for a ROS. I may have to have grease fittings installed on my elbows.
Re: Thanks, all, what a shame....
John McGaw
It might be easier in the long run to put a 1/4" skin of drywall over the whole mess and forget that it even exists. Time is money and sanding properly would take a lot of time.
Stuart Johnson
What about either a sheet on a pole or electric dry wall sander?
You might be surprised
Bill Howatt
at how quickly you can sand the area. I have a cedar house and I've had to sand off failing stain after pressure washing because I should have redone the stain sooner. I do the entire area using a 60 grit paper on my ROS and I wear an anti-vibration glove plus dustmask.
You may require a lighter touch since you are dealing with drywall and its paper finish.
Bill
Re: You might be surprised
I sanded the walls of a room that had been wall papered and the removal had left a poor surface. Long story, but we skim coated it with drywall mud and sanded the entire thing. Doing the walls was not that bad, but in this case I dread the ceiling.
don stephan
My experience is that any ROS sanding grit on drywall paper will fuzz the surface noticeably. Scraping seems likely also to fuzz or even tear the paper coating. The only repair for the fuzz I've found is skim coating the area with drywall mud and light sanding.
A 1/4" added layer of drywall will stand out like a sore thumb at door and window trim and baseboard, and require box extensions for light switches, plugs, and such.
don stephan
It was very messy, but I once thinned drywall mud, put it on with a wide thick nap roller, and immediately removed with a wide trowel. The removed mud needs to go into separate bucket and thinned because the paper sucks out so much of the water when it's rolled on. Perhaps best done by a two to three person team.
