200+ woodworking book reviews
Advise/Recommendations on non WWking Tool
Alan Young
Alan Young
OK I'm looking for an electric hair trimmer-Those who've seen me know the use of such a tool couldn't possibly take me more than seconds before I exhaust any available hair---
Ideally I'd like something that can cut what little hair exists above my ears as well as trim up the goatee and shave the sides of the face. As with multi task woodworking tools I suspect a law of diminishing marginal utility and am willing to get two items if need be-First priority is cutting the head hair-second priority-shaving facial sides-third priority-trimming goatee---
Waiting for suggestions-I'm all ears
-Alan
Re: Advise/Recommendations on non WWking Tool
Mark Nowicki
Wahl is probably the best known brand.
http://www.wahlpro.com/
distrbd
distrbd
I have had a Wahl Peanut clipper/trimmer for 6-7 years, and I am quite happy with it, it has 4 or 5 attachments but I only use the shortest one to trim my beard /mustache and just the blade for outlining my goatie.
it does get hot after 10-15 minutes of constant run but for home use it is perfect.
Alan, have you looked for an attachment for the Dremel? :)
In my experience - and the (unwanted) critique of my wife - none of the electric ones work as well as a scissors.
Regards cold London
Clint Searl
Festool must make a trimmer
Safety First
Let's not get crazy here. Power tools might make the job go faster but they are most certainly not safe in wet conditions. And unless you've had that first cup of coffee, I see all kinds of makings for disaster.
Better to stay away from the power tools and go old school. I suggest a draw knife or a Boggs spoke shave. And keep a Norton stone by the sink.
T.
"In This Life of Toil and Sin
Your head grows bald,
But not your chin."
Burma Shave c
I would LOVE a set like that!
Professionals everywhere recommend...
Finally, a serious thread that discusses the importance of quality tools. I can't help with the fine artistic sculpting Alan's person certainly deserves, but if quick hair removal is needed I can recommend these. I purchased one each of the shears and clippers and can testify they work as advertised:
https://www.premier1supplies.com/list.php?mode=article&cat_id=38
A bargain at $350 each; worth every penny. If you don't believe me, just ask Sparky:
(For my own ugly mug a little rechargeable ConAir served me well for years until the rechargeable battery quit charging. A screwdriver, soldering iron, and a AA nicad and it's been good for another 5 years so far.)
Johanna
Wahl clippers are, I think, the best. I have used both Oster and Wahl animal clippers for many years.
Re: The real answer
TomD
Alan, I have the same haircut, and use clippers, scissors and a straight razor. I cut the family hair most of the time also. I am currently using Conair clippers I think I bought from Walmart. They are sorta Black and Decker, vs maybe Festool, quality wise, but they get the job done, and I have not found a place to buy the grade used by the salons, without spending more than I think I should (ie retail). The conair level of clipper costs about 35-50, and will be in a kit where you get the handpiece, various attachments to determine length of cut and various tapering tools, and then you get stuff like scissors, and clips, and a cloth to protect the victim. Your focus should be on the hand unit when buying, though the rest of the stuff is not garbage it is not all easily purchased or improvised.
If you are new to doing this yourself, something of what Derek says is true. Clippers on a man with your hair will not do a finished job, except if you go down to stubble, in which case it will grow back for a fair while and look decent. That presumes a moving target is decent, which in say an office it would not be. If you want to maintain, say 1/2", you will find that the clippers stop cutting around the bald spot, this leaves the bald spot ringed with a fringe that yells "I am too cheap to get a haircut and bald". Basically the clippers do a great job as long as there is hair backing the cut, on the upgrain side.
You will also have difficulty using the clippers around the ears, not to mention seeing what you are doing. There are attachments that can be worked, and I can go into that, for both these problem areas, but the best thing is a cooperative person with some scissors.
For your hair, as you may have noticed at the barber shop, it is mostly a clipper job followed up by scissors. Some people have beautiful complex hair that can be artfully cut, and for which clippers are probably not the answer, but it is also the case, that in the art of giving a cut, a good deal of messing around is complete nonsense that is only there to fill the quarter hour, and impress the client they are getting value for money. At the other end of the art field, a stylist may use electric clippers, scissors, and razors to cut hair. Clippers are a productivity tool, and do some things really well, for others, other methods work.
You can find pretty good scissors from chinese sellers on ebay. I got a pair of barber shears, and thinning shears for about 4 bucks, finished in a blue Ti. Some of these scissors need a sharpening, and are not the quality of expensive shears, but without getting into it, you can make them work, a lot is open to you if you do not need to send stuff out for sharpening. As we should not need to.
I also use a straight razor for trimming into the beard, and for shaping the beard. I use a stroke as though I was combing the surface of the beard, and any surplus just falls away. I use a straight razor with replaceable blades, which is a bit of a shock to me, but I got into the habit while traveling and that is still where I am at. 6 dollars buy 120 blades, and they last me several years.
The clippers will not shave your cheeks, to maintain a goatee. I would use the straight razor, but you will need some kind of razor. even at the finest setting the clippers leave stubble behind, the lower clipper has some base line thickness, you can't get underneath.
Re: Stihl Manscaping
TomD
Unlike my beloved Stihl chainsaws, their line trimmers are the most useless tool I have ever bought, so I would not be wishing for anything based on that design. :)
