I glued the top up today in two sections and after some time for them to set up I combined them into one panel. The butt joints lined up real nice without going through extra measures to pull them together. There's next to no gap between them.
I used my old standby trick on the end grain joints of priming them with a layer of hide glue first and allowing it to dry. Once I started gluing the sections, a little hide glue on the ends and it sticks like crazy.
All that's left is to trim both ends to final length and sand. The joints came together so well that's all it will take. This darned thing looks like something you could land a small aircraft on!! Hope I can lift it off the bench when the time comes!
Maybe it's my small screen on my laptop-but I can't see the butt joits-Are they over lapped like the Boston Gahden Parquet floor? Or do you have 6 boards with a center line dividing three boards on each side?
Alan, there are three boards (pieces) on the outer rows and four in the center. It's hard to see from that shot because I had to back off with the camera to get the entire length in. Up close you can see the joints but they're tight and should look even better after sanding.
I might need to install a ceiling hoist to help lift that thing off the bench!
are the butt joints there to accomplish efficient use of whatever lengths of lumber you had, or to make edge jointing easier? Or other?
Yes and yes. I had 3 cherry nine footers and 2 eight footers. The nines were wide enough to total the final width I needed for the top. The reason for the butt joints (thus short pieces) is that I did not have the space to be able to run nine footers in and out of my planer no matter where I positioned it in my shop. I possibly could have edge jointed that length but I would have needed to open the walk-in door near the jointer.
The other issue was face jointing rough sawn nine footers without ending up with boards that looked like a giant wedge. My experience is that rough stock too long has enough dips and cup in it that too much is removed trying to get it flat. I was after the thickest finished dimension I could get in this case. My Delta 8-inch jointer has very long beds but I knew shorter pieces would joint easier, be easier to handle, and I still had the space problem already mentioned with planning. It's just too cold to even think about doing it outside.
How ever did you get the widths sufficiently identical to pull this assembly off?
Two of the three boards were just over 6-inches wide and the third was about 8. I needed 19 finished inches. After jointing and planning I cut the pieces for the outer rows to 6-inches and the third to 7-inches for the center row. To stagger the joints I cut the pieces for the outer rows the same length (3 per row) and those for the center cut into 4 pieces.
Thanks, Don. I kept the pieces in order using red marks from rough cuts to finished. I hoped keeping the grain close to continuous would help blend in the butt joints.
I would not have thought what you accomplished was possible. Having seen it done I will add it to the list of what I might try when needed.
Getting the widths of what was to be butt jointed exactly the same, like to within 0.005" at most, had to be difficult. And then there was the task of keeping these butts aligned as the clamps tightened.......
OK-That makes sense! I've done two panels like this an as long as each row is the same width and you glue up no more than a row at at time it works well-This will be a great piece to see come to a finish!
