Sears Oscillating Spindle Sander
Gary Smyth
I have a table top Sears spindle sander. At least ten years old. In the process of searching for sanding sleeves Sears presented a problem of identifying the options for sizes of rubber spindles (inside and outside diameter) and smaller diameter sleeves. (read discontinued)
I'm told that this import is the same as at least one available by another manufacturer. Sears won't provide me details of another importer. Hard to read, but I believe the Sears model is 113.225906, which sources at Emerson, but the trail ends. Ebay shows no matching image.
Anyone know of this model's twin? Ryobi, Jet, Ridgid, maybe.
A call to Klingspor couldn't match up but they believe that if there is a twin, they might be able to assist.
Re: Sears Oscillating Spindle Sander
David Yoho
I have that exact sander. I haven't bought sleeves in quite a while but last year I started looking. Klingspor looks to have them. They are 4 1/2" long. They have the 2 and 3-inch diameters listed and probably the smaller ones too. That's where I plan to get them whenever I order. I couldn't find anything elsewhere.
David Bair
Also try Lee Valley; they have at least 4 sizes.
Ron MacLaren
Gary,
Try this: http://www.amazon.com/s/ref=nb_sb_noss?url=search-alias%3Daps&field-keywords=sanding+sleeves+Powertec. This is what I intend to buy for a Delta Shop Boss, based on my internet research.
Ron
Fairly certain that is a rebadged Ryobi
John in NM
Easiest way to find the sleeves is measure the drums - I bet they are pretty universal OD's.
Woodworker.com has sets, Home Depot has sets for the Rigid version, etc. 4 1/2" long sleeves are pretty common.
Re: Fairly certain that is a rebadged Ryobi
Henry Higginbotham
I thought that, too, since all the Craftsman OSSes that I've seen have been Ryobis. But . . . I couldn't find a Craftsman OEM prefix for Ryobi that could be confused with 113, even if mangled and hard to read. 315 is the most common Ryobi code, I think.
That's why I refuse to buy Craftsman ever again.
Joe Pack
Zero customer service. Proprietary parts. A 5 year old radial arm saw is "obsolete," no parts available. A heavy duty belt sander with an almost new original belt, used no more than 10 minutes after receiving it as a gift, one week after the 1 year warranty ran out...tough luck - warranty is up. Broken ratchet used no more than half-dozen times, offered replacement parts, not replacement; got a replacement when I got loud reading the warranty word for word in front of other customers...
Craftsman is now only a name on overpriced Harbor Freight quality tools. (My apologies to Harbor Freight for demeaning their tools. I have never had a Harbor Freight tool, electric or manual, fail.)
Sears Model/Manufacturer Table *LINK*
David Yoho
According to the table in the WC link the sander was manufactured by Emersion Electric.
The problem with so many power tools today that a manufacturer discontinues is availability of parts. I have a 13-inch two speed planer by Delta that was discontinued years ago. I can't get parts from them. I have to order blades from a fellow on eBay. It's new-old OEM stock but Delta doesn't have them.
fredhargis
I also have that sander, though mine is much older (20 years old at least). Anyway, I was in a HD quite some time back and grabbed a couple of rubber drums for the Ryobi sander and they fit my Craftsman. I did this on blind faith they would fit since they looked the right size. the sleeves I order from Klingspor. Anyway, you might check HD and see if they have any, if they don't fit you can return them.
j q greene
Gary
I have the same sander. A few years ago I ordered several different sizes and grit sanding sleeves from Satco Supply's Closeout Tools at www.tools4schools.com They fit perfect; are of good quality and very reasonable prices. I believe I also ordered a couple sizes of the rubber cylinders from them also.
Check their site under abrasives misc.
Hope this helps.
