Holy Drawers Batman!!!
David Yoho
This morning I went out to the shop to begin dimensioning the rough cherry for the top to the monster dresser I'm building. More on that in a minute. Horizontal real estate is at a premium in my shop. I had all sixteen drawer boxes stacked in a number of spots but needed those spaces while I was working the cherry boards through the saw, jointer, and planer. The only place I had where they wouldn't be in my way was at one end of my free-standing bench. So I stacked them - eight to a stack - and started working on the cherry for the top.
Below is a shot of towering drawers and the cherry and figured Makore fronts that will be attached later.
I noticed the last wood I ran through my planer had enough ridges on it indicating I needed to change out the blades. I pulled a new pack down from storage and began the process of changing or flipping blades. To my surprise I found only one edge had been used and I didn't need to replace them. So I flipped them and put everything back together. The cherry I dressed this morning came out clean and smooth as silk. Wow, what a difference sharp blades make!
I've been bogged down trying to decide how best to make the top for the dresser. It will be just under nine feet long. The two biggest issues for me was trying to joint nine foot 4/4 rough stock and end up with something that didn't look like a giant wedge and not enough space to feed it in and out of the planer. Another issue was how I was going to assemble it if I cut the nine foot stock into smaller pieces and still have it be strong while allowing for movement. I came up with several ideas that just didn't work in my mind. Then yesterday I was looking at my hardwood floor and it came to me - I could cut the boards into shorter lengths, used spline joints like tongue and groove flooring, and stagger the lengths so the butt joints didn't line up. So basically I'll be cutting the three nine footers and then putting them back together. This will still give me the plank look I originally wanted and it was easy to end up with a finished thickness of 15/16. There may have been other solutions to this but my poor brain didn't come up with anything better.
Oh, and now that I need my bench to work on the pieces for the top I had to move the drawers again
