A55 Smoothing Plane
WOT - Whitening Plastic
Have 4 outdoor lantern parts that have gotten pretty yellow over the last 30 years. I've got them sitting in some chlorine breach and water to see if I can reverse the UV-induced yellowing.
Has anyone else here tried this (or am I the only one too cheap to just buy new fixtures)? If so, what did you use and how successful were you in getting them back to white?
Re: WOT - Whitening Plastic
John Veerkamp
I don't think it can be done. The yellowing is degradation of the plastic. You'll probably also notice it is getting brittle and crazed. It if is flat plastic, buy some sheet goods and cut your own replacements. My experience anyway.
Not going to happen.
They are permanently yellowed. Replacement is the only alternative.
Depending on the plastic, you could actually be damaging them with the bleach treatment.
Done - Thanks Guys
Cleaned'em and actually lightened the yellow a bit by sanding with some 120. It was worth a shot, but not going to put real time into 30+ y-o builder's fixtures.
They'll do 'till Memsahib finds new ones somewhere.
Thanks
A possible fix
Auto parts stores sell a chemical that you can put on car headlights to fix this exact problem, which is common as cars get older. I have no personal experience, but I've been told that it works.
Re: A possible fix and something else.
I just tried to refurbish my head lights. Not much help. sanded with 600 grit and then the finer and finer stuff in the kit. Not worth the efforts for me.
Something else to try. The Borgs sell cans of spray paint made for plastic. I just saw that Auto parts stores sell paint made for plastic and fabric. Used for refreshing the interior parts or your car. I woudl try one of those. I have been using some of the Borg stuff to refresh the Washer box and bath vent fan covers in houses I am flipping. Tan. Works well. It comes in white also.
Re: WOT - Whitening Plastic *LINK*
walta
I do not think the chlorine bleach is going to work.
Look at this link, I think very strong hydrogen peroxide over 10% and UV light may do the trick.
I could not find the old link where they concentrated the peroxide. It seems that strong peroxide is an ingredient for things that go boom.
Walta
How to Whiten Your Yellowed Plastic Gadgets
Jerry Roberts
I watched a guy re do my Honda Accord headlights several years ago.Just a guy in the mall. I asked him how he does it and he said Walmart has the kit. I tried it without much luck also.The only thing he did that I didn't is use a drill with a pad for the sandpaper. It took him about 15 minutes to make my headlights look new again.
I bought a kit at an auto farts store. I "enhanced" it by using my drill and a sanding pad to get the major crud off and then polished them with the kit. The outside of the headlights looks great. the problem is that the inside of them is about as bad as the outside used to be. can't figure out how to polish the inside. Time to spend the $80 for new headlights.
