Woodcraft sanding disk sale *LINK*
cameron
I see woodcraft has there 1-day sale on sanding disks again and am wondering if these are any good? There are no reviews but the price seems decent, even though they are only 5 hole disks and my ROS are all 8 holes... 100 disks for ~$14
Thanks
Woodcraft ad
Re: Woodcraft sanding disk sale *LINK*
Jerry Roberts
Cameron, I didn't see what brand they were but if they turn out to be Abranet don't do it. I made that mistake some time ago. I bought a good size pkg thinking it was a good deal. After a few months they don't stick on h&l any more. Never do that again.
cameron
they say non-branded from Finland I believe
cameron
Premium Sanding Discs made in Finland by a leading sandpaper manufacturer. Each box contains 100 5-inch diameter sanding discs with 5 hole pattern. Designed for every day sanding applications, especially with higher speeds. Special stearate coating and semi-open pattern prevents clogging and pill forming for optimal results. 240 grit. -
William Duffield
Hook and Loop abrasive faillure is almost always due to failure of the sander pad, usually due to excess heat due to excessive force by the operator.
These pads are almost certainly by Mirka, who also makes Abranet abrasives. These however, are paper backed, not mesh backed, and are PSA, not H&L.
Jerry, I have had a Porter Cable ROS for years. (Actually two of them) I have a spare disk/pad for them at all times. I get them at Home Depot, less than $15. I find the hooks wear out after a while and replace the disk/pad. Works like new for a while. I did buy a bad batch of sanding disks and they would not stay on the machine no matter what.
William Duffield
I've had that problem with Norton discs even with a new pad, but not Mirka. I've used Mirka 5 hole 5" H&L pads for several years, without any problems, but they don't fit my preferred 9 hole ROS, so now they just sit on the shelf.
I would strongly recommend against using paper with incompatible hole patterns, for health reasons. Even with matching hole patterns, most ROSs create and distribute lots of harmful wood and abrasive dust, and it is exacerbated by inefficient dust pickup.
Nah
The ad says "PSA"
5 hole or 8, got no use for PSA abrasives
Perhaps that's why they're getting "cleared" out?
cameron
Thanks, totally missed to fact that they are psa...
Re: Mirka protector pad
That Ad is confusing. The title line says they come in quantities of 5. The Price is stated as $19.95, but then it says buy five for $18.00 each. So, what do they sell for?
I buy pads for my Porter Cable at Home Depot for about $15. I just put a new one on. Was about to buy a five pack of the Mirka ones and got befuddled.
It is confusing
Dick Coers
And, these are just a thin protector pad, about 1/8" thick. They just keep the heat off the sander pad if you are aggressive. You get 5 of these protector pads for $19.29. If you order 5 packs of 5 (25 pieces), you pay 5 x $18.80.
Jerry Roberts
Well, I learned something. I just assumed the abrasive pads I was using had gone bad after several months in the box. My P C ros is relative new so I didn't consider the pad had gone bad. I just now went out and tried it and this abrasive disc doesn't stay put for over 5 seconds. Its not paper backed. I assume its h&l. Guess Ill make a trip to HD to get a Mirka pad for ros, Man, Ive had bad luck with P C ros es. 6 inch went belly up abt 2 yrs ago and they don't make them any more.
