Wide crown stapler for canvas
Gary Smyth
I have need for a WIDE CROWN pneumatic stapler for canvas and upholstery. There are several available for around $60 and HF has one for under $30 -- much less with 20% discount. I'm in no mood to hand staple hundreds of staples with a hand power stapler and the Stanley electric one I have is more trouble than it's worth and pretty much useless in hardwood. I would like something able to handle 1/4" to 5/8" wide crown staples with a reliable use -- few jams
Please let me know your personal use recommendation. With your thoughts and those expressed on "You Tube" I ought to get a pretty good idea. By the way, later availability of staples is a consideration.
Re: Wide crown stapler for canvas
Re: Wide crown stapler for canvas *LINK*
Jesse Cloud
I have used a stapler from Woodworker's Supply for several years, never had a jam. I use it on chairs mostly, but also for shade cloth, plastic sheathing, etc.
It staples cowhide leather onto hardwood without a problem. I use a 3/8 crown (a wide crown is a hindrance for uphostery, which has lots of awkward tiny spaces), but they sell larger ones as well. Though I've never needed it, they also sell a good range of spare parts for it.
woodworkers supply stapler
Andrew nistock
hi Gary
I use a porter cable US58T2 upholstery stapler in my shop. I have driven at least 50,000 staples with this workhorse without a jam. I do get the occasional bent staple or misfire but a little oil in the back of the stapler where the air line attaches solves the problem. Staples are avaliable at Tools plus. I use the 22guage 3/8 x1/2 inch staples. A box is listed for $7.33 for 10,000 staples. Good luck
Daves Not Here
The Harbor Freight stapler has worked just fine for my occasional usage of wide staples. If your usage will not be an every day type of thing then the HF version would be worth considering.
Purchased HF 20 GA
Gary Smyth
I did some follow up on WC recommendations and internet reviews. Today I purchased the HF 68029 20 GA wide crown stapler, also, a thousand each 1/2 and 3/8 HF staples (it will also fire Arrow T50 staples all sizes to 5/8). Pneumatic oil for all pneumatic tools in the shop, and a full replacement two year extended + 90 day store warranty for less than $42 (after discounts). For the initial application it delivered the first 200+ 1/2" staples just fine. It's doing the job. It's new, but so far a really good purchase. It certainly beats the time and muscle strain of the hand located and fired power shot!!
ChuckinND
I have a hard time buying anything from Harbor Freight ( HF ), infact I'm not even that crazy about Grizzly. I guess that things have really changed over the years in this country, and I don't like it at all. We use to be a country that earned the right to be proud of the products that were made in this country. Now it seems like even the American craftsmen in this country don't care. Not good. Just my opinion.
Ditto the PC US58
Tim Greif - West of Chicago
I have used this stapler on a few upholstery projects over the years. It uses Senco and standard Eagle 71 series staples, readily available from upholstery suppliers. The only misfires were due to air pressure being set too low. Keep the pressure up and this tool is a champ.
Re: Purchased HF 20 GA
Walt
"also, a thousand each 1/2 and 3/8 HF staples"
If you have problems with jams, I'd try some different fasteners before blaming the stapler. I don't know about fine wire staples specifically but people have reported jamming problems with HF fasteners in the past. Switched to a name brand fastener and the jamming problem went away. I have an HF pneumatic stapler and it's been fine for what I've used it for. Very basic tool, no indicator when the magazine is about empty, no double trigger safety mechanism like some have but it does sink 9/16" T50 staples in oak. If Home Depot had the Freeman brand upholstery stapler available when I needed a stapler(they were back ordered), I may have gone that route instead.
