THE WOODRAT IS BACK!
My Seal Coat went POOM!
I had an old partially used quart can of Seal Coat shellac in a metal storage cabinet. Been in there for months, maybe years. Was in the cabinet the other day searching for something else and found the Seal Coat had no lid on it. Was baffled, could not imagine putting it away without the lid. Pulled out the Seal Coat and the bottom of the can was bulged out to the point the can would not sit flat and rocked around on its dome. Found the lid, upside down on a nearby can. It took a while to find it because the lid was perfectly placed on the other can, just upside down. The Seal Coat was brown goop, skinned over.
Apparently there was a reaction with the can material and built up internal pressure enough to blow the lid. Interesting.
Re: My Seal Coat went POOM!
Hank Knight
Barry, that is indeed strange I've never heard of it happening. I've had Seal Coat cans rust through and leak all over everything, but never had one blow its top. I wonder what caused the pressure build-up.
Michael Dresdner
SealCoat is shellac, which is acidic. For that reason, it is sold in epoxy lined cans, so the acid can not react with the metal can or solder. Most acid metal reactions generate various gases. In a closed container, gas will take up more room than liquid, and can pop a top as you describe. In short, I'd say something happened to compromise the epoxy lining, either when it was made or after it was opened. Stirring the shellac with a screwdriver, for instance, can scratch through the epoxy.
William Duffield
"Leak all over everything" has happened to me too, but never "Poom!" Now I keep powdered shellac in a glass jar in the refrigerator, and mix it with Everclear as I need it. It dissolves a lot quicker than flakes, which I also use when I manage to plan ahead.
Powdered Shellac
Shop Tip:
Shellac flakes quickly become powder using a chopper-in-a-hopper. Just make sure you get one for the shop as SWMBO will not appreciate you using her GKTs (Good Kitchen Tools).
:D
PS: Using Parks DNA (less than 10% methanol) is way cheaper than Everclear!
Hank Knight
William, the best part of your method is that, when things go really bad, you can drink the everclear. :D
question
The process used to make the stable shellac (precipitation from base) is designed to remove the acidic, or at least the more strongly acidic, shellac components.
Does enough acidity remain for the shellac to remain acidic?
If so the cause of the pressure build up is apparent.
H+ (acid) + exposed iron = hydrogen gas plus dissolved iron
Barry, stop stirring with a screw driver!
Re: question
I never stir with a screwdriver anymore. I did once and it ate the end off it completely, in seconds. Can't afford to lose my only other screwdriver.
I stir with a stick. Occasionally they burst into flames.
Actually, I seriously doubt this can was ever stirred with anything. Most probably shaken gently and decanted a couple of ounces into another container and the lid put back on.
I am not particularly upset about this, I just thought it was interesting.
Re: question
Michael Dresdner
Short answer: Yes, shellac is acidic.
I can't imagine this is of interest to anyone, but here goes.
What you may be referring to is the process of making shellac water soluble, which involves treating it with an alkali, but as far as I know, that has nothing to do with SealCoat or any other shellac cut in alcohol. The longer shelf life shellac (which may or may not still be used in SealCoat) was created by suppressing esterification. Again, still acidic.
And to Barry -- this is not the first time Zinsser heard about cans with compromised epoxy coatings, so I was not suggesting it was you. I just figured it would be a good place to gently suggest that others out there not stir shellac with a screwdriver.
Rum
Hah, I think perhaps? the weather has something to do with it as well (or at least accelerates the process perhaps...) as I had two cans (of dubious history and age) do the same thing within the last couple of weeks. They were due to be tossed anyway so no great loss but amusing timing anyway.
Not sure when - I went to grab some stuff from the cabinet saturday and there they were, one can was pretty much full and had swollen some before blowing the lid, the other was mostly empty and had just popped the lid. I know they were good about a month back (or at least the one can was anyway).
I have studied the patent
Don't underestimate the scientific curiosity on this Forum.
The Zinser patent describes the process for preparing more stable shellac. The raw shellac is dissolved in base and then the acidity adjusted to precipitate all but the most acidic components, which apparently are the components that set off the polymerization reactions that render unrefined shellac alcohol (and every other solvent) insoluble over time. The precipitated shellac, free of the more strongly acidic components, becomes the product.
Re: I have studied the patent
Michael Dresdner
Yes, you are correct, but the problem exists even with the so called C5 shellac resin. To wit, by reducing SOME of the MOST acidic components, the process slows (but does not stop) esterification. In other words, while it may be LESS acidic, it's still acidic, and certainly acidic enough to A) create the problem described and B) necessitate Zinsser using epoxy lined cans.
FWIW, we went through a huge bubba meise with this issue when we were talking about the French Polish they made briefly. Ultimately they chose gold colored aluminum cans. (I pushed for squeeze bottles, but those created a different problem altogether.)
