Demilune- cock beading the drawer
Cock beading the drawer
PIC 1 cock beaded drawer
Step one is to decide on the thickness of the cock bead. If my experience is any guide the ideal thickness will be less than first envisioned. I was thinking 1/8” for this drawer but in fact I wound up at 3/32” at what I thought looked well proportioned to the drawer size. The cock bead will cover the entire top edge of the drawer to protect the veneer edge and cover the secondary wood of the drawer substrate. More narrow bead will partially cover the side dovetails. Depending on what side of the Atlantic ocean you work the bottom bead will be like the top(America) or across the ocean it will be narrow like the side bead. A discussion of these choices is posted in more detail on the Hand Tool Forum. In the drawer shown there is a partial cock bead on the drawer bottom, the genesis of which is discussed on the Hand Tool Forum.
Once the above decisions are made material is removed from the drawer to accommodate the cock bead thickness. Preferences might lead to planing, chiseling, sawing or routing away this waste. Whatever the choice, at this point the drawer is made, fitted and the perhaps one of a kind veneer glued on. It is not a time to make a mistake excavating the drawer for the cock bead.
PIC 2 Installing locating pins
The way I fit cock bead involves temporarily installing it, removing it for further refinement and reinstalling, several times. There must be some means of repetitively locating the bead on the drawer which is accomplished by “dowel pins” in the form of cut off brads as shown in Picture 2. The brads are cut leaving about 1/16” projecting. Once the cock bead piece is pressed into these pins its location on the drawer is fixed.
PIC 3 marking profile
The cock bead piece is pressed into position and its profile marked with a gauge block and pencil as shown.
PIC 4 Planing profile
After sawing the waste away the bead board is reinstalled and the profile planed to result in an even extension of the bead board edge beyond the drawer face. If the bead is to be a half round profile the bead should stick beyond the drawer face about ½ the bead diameter. Note: I find that if I plane with the bead board on installed on the drawer I can get an even projection of the bead beyond the drawer face, essential for good looks.
The profile is then scraped on the bead board edge. If the profile edge is first started with a plane or file, scraping the half round takes but seconds.
PIC 4 bead board reinstalled
What comes next looks harder than it turns out to be. The picture shows the oversized bead board overhanging the end of the drawer. The length is planed flush with the drawer side and the intersection of the partial drawer side cock bead with the top bead board is accurately marked with a knife scribe. The mark defines the end of the stopped miter to be cut that will join the side cock bead with the top bead.
PIC 6 Paring stopped miter
The partial miter is cut with surprising ease with the aid of the fixture shown in Picture 6.
PIC 7 gluing bead board
PIC 8
The rest of the cock bead installation is just more of the same, gluing the fitted bead boards on as they are fit. The glue must be applied with care so that there is not excess to squeeze out onto the drawer front. I find a brush and glue pot helpful for precise gluing application.
