Re: To answer your actual question
TomD
It is a good question, there are some sneaky things that can happen...
1) So when doing cuts that cut both sides same time, you have balanced forces in line with the cut, the right side is pushing back and the left side is pushing in, and they net out. Unless you pushed two edges together that were uneven, where you could at some point be cutting heavier on one side than the other.
The lateral force is all to the right.
2) If you are using a template where you do a pass on one side, then the other, you need to feed each in the right way, or you could end up climb cutting.
3) not all climb cutting is bad, joinery wise you can make the final cuts with very slight cuts, these might be controllable in a climb direction, and it might yield a cleaner cut. This approach is used in some dovetail jigs where one scores the surfaces, then powers the waste. It is also the strategy things like table saw with secondary blades use. And many metal working machines.
There are also certain router cuts where climb cutting blows away material but never quite snugs up, leaving one to waste material quickly while always leaving a hair to be taken out in the self setting direction. An example of that is freehanding router pins, at least as far as the waste is concerned, in that case the precision is hand sawn.
