Trying to inlay top of ring box with an inlay kit. Cannot get air tight fit and don't know what I am doing wrong. Using 1/4 cedar for the patterns. Could that be the problem because of soft wood? Anyone have any suggestions?
We might give better advice if we knew more about your "inlay kit." Is it a set of matched bushings for a router? Templates that you traced onto cedar?
A shot in the dark... if you are using router bushings its critical that the bit is perfectly centered in the bushing. Thats a tricky adjustment with the screw-on bushing holders. If you have a centering cone that chucks into your router collett, the process has a better chance of success.
It is a matched kit from Whiteside with a bushing and a centering cone. I keep the router facing the same way when routing the inlay and the recess. I am using a Porter Cable model 6902 and there is no perceptible play in the shaft when locked in place.
The first thing I do with the kit is replace the bit with an uncut spiral. I hate down cuts, and I hardly ever get more than fuzz on the top of the cut. Can't say it will help with the fit though.
Are you re-centering when you change bushings? I had a set where one pair was slightly off. You might also "mic" the bushing walls to be sure they're machined properly. Holding the router in one orientation means that your cut is being guided by at least 4 different points on the bushing's outside surface. Doesn't take much to multiply an error.
Soft wood could translate to the cut being too wide on the face grain axis but tight across the end grain, but seems unlikely. Such an error should be duplicated with both bushings and still give a tight fit.
I have not done this in a LONG time so my memory and perceptions may be wrong. As I recall if you cut around the inlay piece in opposite directions, clockwise/counter clockwise, you get different results. Same may be true for the recess. The bit tends to lead into the work in one direction and out in the other. Again, as I recall I was using an 1/8" bit. Play with direction and see what happens.
I've never used one of these kits, and don't know if they come with a bit which is suppose to match the bushing differences. It sounds like your bit is too large, if the inlay part comes out too small to fill the space. If you have the means to grind the bit down, I think you only need to reduce it by half the amount.
You mention your PC router, which should be fine, unless the bearings are old. The bit however could be the cause. 1/4" shank bits can flex quite a bit, especially when you have a lot sticking out of the collet, which is sort of required when template routing. However, you might want to take care to make sure you only have as much as you need, and no extra.
When I'm inlaying something I've done freehand, if the part is too tight, I find it helps to sand a slight bevel on the backside to help wedge it in.
Used same cedar templates with new 1/8 inch bit. Minimum amount of bit extending from collet. Routed inlay counter clockwise and recess clockwise. Fit was much improved. Not wedge tight but acceptable. Thanks for all the help.
