16-Drawer Dresser Update - drawer boxes
David Yoho
Since there was interest in this project, I thought I'd post several update shots.
This project is one where I have to juggle how I go about what I do so that I follow my customer's wishes, his budget, provide overall quality, and still make some money for my efforts. Although I enjoy using time tested joinery like you would see in high end furniture, this job leaves no room for that. However, I am using good joinery, albeit simple, that I know works and will last. It has to since I always stand behind everything I make until I leave this Earth. So far, nothing has ever come back!
I thought I would show a little about how I made the drawer boxes. The finished drawers will each have a cherry and figured Makore front attached.
After re-sawing 4/4 Spanish cedar stock, I planed the pieces to 1/4" thickness and glued up the 16 drawer bottom panels. After removing the panels from the clamps I had to deal with the glue squeeze-out. I start by scraping the hardened hide glue using a paint scraper to remove most of it from the surface.
Next, to smooth and flatten any uneven joints I turn to my Stanley #80 cabinet scraper. After that I sanded the panels to finish them off.
The following picture shows the last of the 16 drawers before assembly. The two parts on the right are the sides with a simple dado that will accept the back. Next to them is the front with rabbets on the ends to accept the front of the two sides.
One thing I found that works well when gluing end grain with liquid hide glue is to prime the end grain by laying some down and wiping it with my finger. This prevents the glue joint from being too dry.
The last picture shows a drawer box completed. The cedar bottom slides into the groove from the rear and under the bottom edge of the drawer back.
Next up I will begin to figure out the spacing for the slides and mount them to the case and drawers. Then I can begin work on the cherry fronts and cutting the 3/16" figured Makore veneer that will go on them.
Re: 16-Drawer Dresser Update - drawer boxes
Thanks for posting this, David. I was curious after your earlier reply to me.
Can you show a picture or two of the Makore you are using?
Figured Makore
David Yoho
Here's a shot of the Makore. On top is an off-cut from a prior project with only a coat of varnish to bring out the figure. Pretty stuff.
