Made a branding iron for wood, on Turning *LINK*
I thought I posted this earlier but maybe I forgot to click the post button.
In case someone is interested and doesn't read the Turning forum, I posted a message there with pics and process of my first try at making a branding iron for woodworking:
Making a branding iron
Re: Made a branding iron for wood, on Turning *LINK*
ChuckinND
I made one several years ago using my initials. It's a little cruder then what you show, but it works. I'd describe it as made more like an old cattle branding iron on a much smaller scale. Using maybe 1/8" thick X 3/8" wide steel bent into letters. The 1/8" side being the branding face.
Chuck,
I debated with myself as to how to approach this one. At first she showed me a logo that was about 3/8" across and I was going to try to carve the whole thing by hand with rotary tools. I thought about sliver soldering brass pieces onto a solid piece but that sounded tricky (and what if someone used mapp gas on it?)
I considered heli arc welding triangular 1/8" strips onto a steel base but really wanted to use brass instead of steel. When she decided on a larger logo I thought I'd try the milling machine - it was easier than I thought!
If I do another one for myself I will try to mill the chamfers as well - I ordered a pointed carbide end mill I think will do the trick. A few people have asked me if I could brand my initials into one of the turnings I make.
ChuckinND
John, Don't get me wrong, yours looks really good. I just don't have a milling machine, or even know how to use one. Actually I'm even a rookie at welding. I wasn't trying to make it sound like what I did was better, because it's not. I do think that branding irons are nice to have, a brand can add a nice touch to a project.
Oh no, I didn't take it that way at all! I am interested in all different kinds of doing this for the future - I'd love to see a picture of yours if you have one. I've seen them bent from round pieces of bar and welded together.
I searched for pictures and saw different construction but I couldn't do most of them, except for maybe a real cattle brand! We make use of what we have.
I think a lot of people would like to have one, any kind. I showed this one to a woodturner friend and he said he almost had one made but it was too expensive to get done.
Do you find it a little scary to put hot metal to a finished masterpiece? I worried about that, even when branding the back of the handle. I made three cherry practice pieces with the same shape and practiced on those first before I took a deep breath and branded the handle!
I saw a picture of one setup where the branding iron was mounted in a drill press. This sounds good - you could keep it straight and control the vertical height perfectly. That would be great if doing a number of things the same thickness, like cutting boards, say.
ChuckinND
John another thing that I liked about the one that you did is that the lines are thin. The one that I made the lines are of course 1/8" wide. The whole brand is maybe about an inch square, and after burning I have to sand it some to make the lines more crisp. I suppose that what I could do is maybe file the branding edge to a thinner point as you did. I don't do any turning, what I branded was some old post office door bank boxes that I made for family and a couple friends. I branded them on the bottom side. I'll see if I can find some pictures of what I did. I wish I could post pictures here without them being on a different webpage.
All the photos I use are uploaded instead of linked.
If you haven't seen it, there is a FAQ page link in the menu banner above that has instructions. Basically, you have to reduce the photo disk size to 100k or less. I use Photoshop which has a function for this, but there are other ways, some described in the FAQ, I think.
I think another way would work, but a bit roundabout: upload the photo to the Member Gallery then link to that in a message.
