Re: Router Table Top
Jim Dillon
Doug, Happy Holidays to you too. I've had my Porter Cable 7518 (14.5 pounds according to Amazon) suspended from non-laminated 3/4-inch MDF for 20 years with no obvious sign of deflection. To be clear, the MDF was placed on ordinary 1x4s on edge along the table circumference and surrounding the plastic router opening. I guess it is like one-half of a torsion box.
To digress a bit. I built my router table into my TS extension table which is a real space saver. The only problem I have had was accidentally placing some very wet pressure treated lumber on the MDF for several days. When I lifted the lumber, I discovered the moisture had swollen the MDF slightly. The MDF had been coated with multiple coats of Watco. After a month or so, it had shrunk a bit and is usable but not like it was. The router table portion was OK. Your phenolic laminate should work well. I made my bandsaw table from the stuff and it is really nice. Good luck. Jim
