JET precision tablesaw fence system JF-10
ChuckinND
I'm curious if anyone has had any experience with this tablesaw fence. Does it lock only on the front rail ? Would you consider it to be an accurate fence ?
Re: JET precision tablesaw fence system JF-10
Mike Van Pelt
It is not bad! Not as exact as the high performance fences..... but works good! In my humble opinion not worth an upgrade.
ChuckinND
Mike, I know that the fence was discontinued quite a few years ago. There is one up for sale locally, new in the box. My situation is that in my other shop, a small shop in our basement that I tinker in the winter months where I have a small 9" Rockwell Contractor's tablesaw that has the original fence that locks both front and back. I have a Unifence on my other saw out in the main shop and like it. I could buy a new Delta T30 fence system for about $200 for the 9" saw, but would I really be gaining that much over the JET that I can get for $50 ? I'm trying to save a few bucks because I don't use the saw that much, but I don't want something that I'm going to regret either.
Mike Van Pelt
sounds as if you found a good deal. you could always put it together and give it a try knowing that you most likly will get your monjey back if you decide that it is not the saw for you and you then sell it.
Merry Christmas
ChuckinND
More then likely I will be keeping the saw, it's a Rockwell 34-607 that has the solid cast iron wings. What I like about the saw is that it is about 25% smaller in physical size then the 10 inch models. Comparable in size to todays overpriced imported plastic and aluminum Jobsite saws, but built much better. In my opinion it's a great saw for a person with a really small shop such as I do. So anyway, for that reason I don't want to waste my time and money with a fence that I'll regret.
ChuckinND
Well I might have run into a problem with using a Delta T30 fence, it locks down on a rear rail. And as I mentioned before, the top of the 9 inch saw is smaller then a 10 inch saw. I was hoping that the Delta only locked onto the front rail. Now does anyone know if the JET only locks to the front rail ?
David Yoho
This is probably no help but I have the newer Exacta fence on my Jet 10" and it only locks on the front. I can't say what the earlier fence does.
William Duffield
Why don't you study the parts diagram? It should be out there on the web somewhere, either at JET's website or at ereplacementparts.com. It will tell you really quickly if there is a latch at the back of the fence and some sort of linkage from the fence handle to that latch.
I'd do it for you, but it's really something you need to learn how to do for yourself (and I have no interest in ever using a saw like that). ;)
Another way I look at it is if I needed two shops, because I got that much snow, or those bitterly cold temperatures, I would use my tracksaw in the second shop instead of a second table saw. I realize they are expensive and are not seen on the used market nearly as often as small contractor saws, and therefore are not the solution to everyone's shop problems, but they're also convenient to have around for breaking down plywood and MDF, especially if you have a small shop.
ChuckinND
William, I realize that people in woodworking forums do not like Contractor's table saws, but thats another subject that I'm more then willing to debate when your ready to start that thread. Your suggestion about looking up a parts diagram in replacement parts worked to my surprise, and I'll thank you for that. http://www.ereplacementparts.com/jet-jwts10jf-708301-table-saw-parts-c-32652_32759_168412.html Trust me, I have not been a slouch when it comes to trying to find info on a fence that has been discontinued for a matter of years. I've done a pretty extensive search for a couple of days trying to find info on it. JET themselves didn't even have much info, other then it's obsolete. Anyway, it looks to me like it only locks onto the front rail, just what I need. I noticed that it has two piece rails, but thats ok, with a small saw top like I have, I can probably do without the short pieces.
ChuckinND
Well once again to my surprise a JET table saw that has that fence come up for sale this morning in our local classifieds, and has a picture of the far end of the fence that shows me that it glides on the rear rail. When I started this topic I was not expecting anyone to go out of their way to find the answers for me, I was simply only looking for someone here that may have had some experience with this fence. http://www.bismanonline.com/next_to_new_jet_contractors_table_saw_10_1_1_2_hp/?app_track=watchListMemberCenter
William Duffield
I like contractor's saws OK. I've built lots of furniture using them, and even wore one out. At least they'll do in a pinch. I just like cabinet saws better. What I don't like is rip fences that lock down front and back.
If SawStop had come out with a contractor's saw first, I'd probably have one now. But they came out with their pro cabinet saw first, and I decided to get one immediately. So far, I haven't needed the technology, but who can predict those things?
The only JET saw I've used had the sliding crosscut table, which would be an advntge, if I could fit it in my shop.
ChuckinND
Everyone has their own needs. If I had a dedicated shop, and more money then I knew what to with I might have a stationary Industrial cabinet table saw in my hobby shop just to fit in with the crowd. But thats not my situation. I've been mostly a hobbyist woodworker all my life, I know what works and what I need, and the Delta with a Unifence, and Rockwell contractor's saw that I have been very good saws for me for all those years. The gimmicky SawStops I could careless about, there are plenty of other tools and machinery in the shop that will take a bite out of us. In my opinion Contractor's table saw bashers are people that have had a lesser brand saw with a poorly designed fence, and or didn't know how to plug a saw into an adequate electrical circuit. Or they are just machinery salesmen. Thanks anyway, but I'll keep my American made saws that I'm proud to own, no matter what anyone else says.
David Bair
My 90's era JET contractor had a stock fence that was usually known as a JET Fence. It locked to a propriatary front rail and rode on a chromed back rail. It wore out in a few years and would not stay securly locked at the desired setting. It adjusted for square by using the four bolts on top of the fence but got forced out of square easily, like when pushing through a piece that spread as it cut.
I could not find a way to remedy either situation and ended up finding a JET cabinet saw rail set and a Powermatic fence that I mounted on the contractor saw. It's locking parts have also worn out but I've been able to replace the pads and it continues to work fine.
ChuckinND
David, did the fence head look like the picture that I posted at the begining of this thread ?
ChuckinND
Well the fence that David Bair is talking about sounds like the JET fence that I'm looking at, but it looks to me like the fence that I'm looking at to adjust the fence to be parallel with the blade is similar to the adjustments on a Unifence. A set screw on both right and left sides of the front of the fence head, instead of adjusting it with the four bolts ontop of the fence rail as he describes.
David Bair
Sorry it took so long to get back to you. I was on the Christmas road a lot the last 2 days.
It looks exactly like the second picture, the upside-down taken from the out-feed side. The first photo, from the in-feed side looks slightly different from what I remember from 10 years ago. The main problem was that the smooth face of the front rail was where the locking lever applied friction. If you affixed some PSA sand paper to this face, it might work well longer.
ChuckinND
David B. On the Unfence you could adjust how tight that the fence locked to the front rail by adjusting the left and right set screws on the face of the fence head, that also adjusted the fence parallel to the blade. Did you try that ? Or did yours not have those set screws ?
David Bair
No, I didn't. There was no provision for adjusting the locking mechanism and there were no set screws to adjust for square or locking on the JET fence.
On the Uni clone, the nylon set screws were adjusted as deeply as possible; the problem was the pad of the locking mechanism. It lost it's adhesive and I could't find a glue that would work for more than a few weeks. I replaced the pad with a segment of garden hose that has worked well for several years.
ChuckinND
Thank you David B. The guy with the fence hasn't contacted me back yet after my last message to him. I don't know if his ad expired on the date that it was suppose too, or if he sold it. He wanted $100 for it, I offered him $50, and he said $50 cash ? I said yes, and haven't heard a word back since, and the ads is gone. Who knows whats going on around the holidays it could of slipped his mind. The reason that I haven't went to look at it, is that he lives out of town somewhere on a farm. I seen that one new with rails in a sealed box in ebay recently went for $39 plus shipping.
Pete in Holland MI
I have the same fence on my saw and am tickled with it. Looks like my saw too. Mine's 18 or so years old and going strong (gets used A LOT). Locks only on the heel side. The aluminum extrusion that the thing locks to and is mounted to the table is about 3" square and unique in profile, thus you'll need it, along with the chrome plated square tube on back of the table.
Biesmeyer? No.
Better than your front & back locker? 100 times. Slide it into position & lock it and your done. No fiddling around with the nose anymore.
You'll be happy, once you figure out how to adapt & mount it to your saw.
Pete
ChuckinND
Thankyou for the reply Pete. The fence that the seller had up for sale comes with the front and back rails, and supposedly all the hardware. It looked to me like it was never used, still had the original box, the rails and hardware in plastic.
ChuckinND
I gave up on the guy who has the fence system. He replied back this morning telling me that I better hurry up before he changes his mind about what I offered. I got this message without him answering a earlier question that I had about all the parts being there, including the manual. So anyway, thanks to you who have given me some information to go by. Maybe someday I'll get lucky and find a used Unifence locally. If not, oh well. I don't use the saw all that much right now anyway.
