Felling and using my own wood for cabinets
Terry Alexander
Really this is coming from my son. He is building his own house (slowly but VERY precise). In an effort to save money, he is thinking of using trees from his property to build his cabinets (I will be doing all the cabinet construction). He said there is a sawmill close by.
I admit that I don't know anything about felling and using raw wood. Here's what i "think".
First, i doubt the mill would want you to bring in 1-3 trees at a time.
Then, once the wood is rough sized, I "think" it has to be kiln dried for a period of time.
He said he has lots of pine trees and 1 huge pecan tree. I just think I can get pine from my lumber yard (where I have a commercial account) much cheaper and faster than where he is going.
So those of you that know about getting from a live tree to a finished piece of stock, please jump in and let me know.
Thanking you in advance.
Terry Alexander in West Texas (where we mostly have pecans and mesquites!).
Re: Felling and using my own wood for cabinets
From the perspective of someone that has spent a lot of time logging, drying and building....there is a lot one needs to know to get from tree to useable lumber. It may be that the sawmill will be able to provide the help needed. You might read my series in the Wood central Articles section on "where hardwood lumber comes from".
Trees are like steers. for every pound of steak (cabinet grade lumber) there can be a lot of hamburger that one has to deal with. If the logs are any good it makes more sense to sell the logs and buy what lumber you need all ready to use.
Jesse Cloud
I'm no expert on felling, sawing, and drying wood. But I had a friend who was in the same situation as your son and here's what he did...
First of all, he recognized that the trees on his lot weren't going to yield many wide and clear boards. He bought wood for his cabinets, doors, etc.
But he had his trees harvested and sawn, put them in a homemade solar drier to dry for a year, then used what came out well to make moulding. He got base, quarter round and sills for most of the house. Bought wood to make what was still needed. Saved a lot of money.
Key thing here was that, like your son, he was taking his time building that house - turned out to be about 3.5 years, but it was a beauty!
Jack Guzman from Maine
My brother-in-law has a woodmiser sawmill. He dropped pines on his property and milled them into boards. He stickered the boards for a year and then brought them to me. I built him a nice set of kitchen cabinets with the wood.
My point is that it can be done and it isn't that hard. He will have to dry the wood however.I like the way he thinks.---Jack
TomD
I own a chainsaw mill and have been making my own lumber for 30 years, almost. If you don't own the saw, and the harbor Freight one seems decent, and they are easy enough to make if you are into that sort of thing, and the payoff can be an afternoon... Your best bet is to see if anyone in your area has a bandmill/woodmizer and comes out to properties to saw wood for the owners. Don't expect this to be free, consider it like a taxi ride combined with some machining time, it will add up fast. But so will the wood.
If you have an indoor area to store wood, and do some minimal stuff to take care of it, mostly stickering it and painting the ends, you will get a very good yield. Kiln drying is not necessary or desirable, it is just the usual industrial haste. A general guideline is 1 year per inch, some woods are much faster, others are slow. If he is really proceeding slowly the wood will be ready when he is. You can certainly store wood out of doors, but there is usually more loss. It is mostly common sense, plus reading a few articles, or looking at some youtube videos.
TomD
Oh, I should say making your own lumber is normally easy, when the logs are on the ground. Felling trees is a whole other thing.
I have a Woodmizer sawmill and have cut and milled a lot of wood over the last decade or so, mostly for farm use. I refuse to cut trees on my property for wood since I like live trees. I will saw them if they fall down, need to be cleared for another reason, or if someone gives me logs.
There may be more to making useful lumber than might first be imagined. The idea of using your own trees sounds romantic and economic but there are a lot of expenses too.
As TomD says, cutting the trees is an issue. You need equipment to cut AND haul. I use a tractor and bobcat plus a diesel truck and 18' gooseneck trailer to haul.
It can be horribly dangerous work. A lot of people have been killed with trees, including a friend of mine. A neighbor went to the emergency room because of one branch. I recommend the book "The Good Woodcutter's Guide" for a great introduction to some of the ways to get hurt bad or put in the grave. I get someone else to cut big trees for me.
Unless you like the mix and match look, you will need access to enough of the right kinds of trees.
Felling the trees is a lot easier and quicker than cleaning up the limbs and brush, especially in the summer time with the leaves and bugs and heat.
Ends of logs should be sealed to prevent loss. I bought Anchor Seal in a 55 gallon drum. It is real expensive if you buy it by the gallon.
Many people who have sawmills will cut the lumber for you for a price or for shares. If you haul the logs, someone with a small mill should be able to saw just one or two at a time.
After the trees are hauled getting useful lumber from the sawmill can be hit-and-miss. Some logs look great but are junk inside with insects, rot, splits, and worse, ring shake.
Some trees have nails or barbed wire in them which will ruin a $30 blade in a millisecond.
Air drying lumber is a very slow process and doesn't always work out as you hope. If you don't stack and cover it right you end up with junk. Boards can also warp and split and get full of bugs. You might need to cut a lot more than you need or risk running short. And I've heard of people who had lumber stolen from their drying yard.
It is quicker to kiln dry the lumber but that is another expense.
After it's dried don't forget you have to plane and edge it.
If this all sounds discouraging, sorry! It's a WHOLE lot quicker and easier to buy dry, surfaced lumber in the desired lengths. Sawing is a lot of fun in small quantities and if done as a hobby or to get special things like thick slabs or rough siding. I think you could end up with cabinet lumber but I'm not sure it would be cheaper or better than just buying it.
An option: I do know that some sawmill operators sell lumber at good prices. Before I got my mill I found a guy with a huge amount of air dried walnut, cherry, maple, poplar, cedar, oak, etc. for $.50 to $2 a board foot.
I also bought several trailer loads of red oak (green) for $.15/ft from a commercial sawmill. It was pallet grade which meant it had knots, splits, wane, etc, but it was cheap enough that I could still get a lot of clear lumber from it.
TomD
I would agree you can't really beat buying lumber on price. Of course you can get it cheaper, but if one was being purely pragmatic the time spent getting your own would be better spent developing sources. Plus you can buy lumber from anywhere in the world. The biggest limitation for me is that the trees that grow on my property are mostly not from species I prefer. But then getting access is never really a problem either. Free wood is normally not worth it because people generally want you to take down some desperate wreck and you really need to have total control over the choices or you will end up doing things you probably aren't prepared for. I remeber a guy who wanted me to cut a 36 inch diameter elm. I could use that much elm up in several lifetimes, nor would I want to fell it.
The danger of felling is probably not worth it, but that applies to many of the sweeter things in life. Don't take on some horrid job because you want to save a few bucks. The other guy's health insurance is usually a better bet. But I will do stuff, on the same basis I have done many dangerous things over the years, for the lifestyle. I had to handle a lot of dangerous snags after the hurricane of 2014, and it was fun, and I learned a lot. You can get killed and maimed in many ways, my worst injuries occurred from banking.
I assume in this case the desire to harvest is for the joy of using one's own wood, that is perfectly reasonable, and makes a lot of sense. I would not discourage it.
The beauty of the chainsaw mill, is one doesn't have to move anything until it is in final form, plus a little water.
But for me that has never been the point
Kneale Brownson
There's something special about your own wood
Kneale Brownson
I made the neighbors a crib for their first child from wood from a big oak that had been on our property line. I'd had a mill cut up the logs and I air dried the boards for several years before I processed them. They liked the fact we had shared the wood.
John in NM
It sure sounds like a false economy to me, but having been in exactly the position your son is in, I can tell you that such thinking is entirely natural. I used to fret unduly over the cost of a pallet of portland cement, wasting a lot of time through not wanting to simply pay the cost and move forward. By the time we were living in the house, I had shed much of the tendency to ignore the value of time.
If saving $$$ is desired, find a small mill that will sell you #1 common hardwood and work around the knots. I doubt very much that waiting a year or more and learning a whole new (and dangerous) trade is going to save much money on what is arguably some of the cheapest lumber around - pine and pecan are not especially valuable lumber woods.
There are a lot of things I can't tell from your question, that I would have to know before I would advise you! Bill probably has the best answer unless:
(1) You are knowledgeable about felling trees. I burned firewood for about 8 years to heat my home, felling all the trees myself. It can be very dangerous if you are not familiar with all the things that can happen. (I learned this some 55 years ago, cutting with an Axe and 2 man crosscut!).
(2) You have the equipment you need to cut, load and move the (often tons) of trunk to the sawmill and haul the finished lumber home, and you have the shop equipment to easily turn the rough sawed lumber into finished material.
(3) You have a place to store the lumber (and are willing to wait a year or so for it to dry and stabilize) and or have you gotten a quote from a mill to cut the lumber, and kiln dry it for you? If so does it seem like it is an economical process.
As Bill has said, much of the lumber may not be usable for your project so figure a loss of at least 50%
Note that solid lumber material costs usually are a fairly small portion of the cost of producing cabinets if you figure your labor costs, finishing material, hardware, etc.
If all of the above item do not concern you then by all means go for it, in my opinion Pecan is one of the prettiest woods to use in cabinet building, also with its varied grain and color, there is little matching to consider. If you plan on using pine, I feel sure you are correct in believing you can probably purchase finished lumber easier and cheaper than sawing the trees.
TomD
That last phrase got stranded, the point it has never been was about the money. Most woodworking is not a huge money spinner or the woodworkers would all drive Mercedes. Making stuff exactly the way you want it is what it is all about and in that regard the wood can't be ignored any more than any other part of the project. Even at the level of saving money there are huge gaps in the US economy. People today get by with some products that while cheap are crap. Shoes, clothes, furniture (lessor extent), and certainly food are examples of an economy in the richest country that ever existed that consistently delivers crap. Sometimes you just have to do it yourself.
Pine
Walt
I haven't been involved with sawing and drying wood so only know what I read. One thing I seem to recall about pine is that it needs to be kilned to something like 160 degrees to 'set the sap' so it doesn't bleed once finished. Hardwoods don't have the same issue.
Re: Pine
William Duffield
That's (one reason) why Zinsser makes B•I•N.
Sorry, I can't find any smiley faces on this iPad. While Zinsser's product is excellent for sealing stuff into wood, it's still not a perfect substitute for hardening the sap with heat.
William Duffield
What self-respecting woodworker would want to drive a Mercedes? I can't haul rough cut lumber in it, or my chainsaw and gas can, or tables and chairs, or even my large dogs. ;)
I Found my smiley faces again. It must have something to do with signing in with my password, and not the iMac's fault.
and don't forget "blue stain"
If it is warm pine will turn blue to black in a day if not properly cared for.
Woodmizer has a contest
DizD
each year for users. On their website you can see photos of what some have done, including interior projects. If you ask, Woodmizer may be able to put you in touch with owners who have done projects like you are proposing.
Do you Mean Denim Pine?????
Blue or "Denim Pine" brings a premium on some wood websites. Its a rare high end product.
Re: Do you Mean Denim Pine?????
It is only rare at companies that know what they are doing drying pine.
Not thinking a local drier put 30000 feet in a dehumidification kiln right off the saw. The initial conditions were perfect for mold growth and when warm it takes but hours to begin staining. What came out was 30000 feet of "denim" pine.
TomD
They do make trucks. Seems like a Wendel Castle level of worker thing. But generally, I would have to agree.
