Screw size question......
I buy machine screws fairly often. No. 4, 6, 8, and 10's. The question is, What does the number stand for? Is it 1/32's of an inch? Seems like I should know this.
Re: Screw size question......
Here's a formula:
Diameter=(number)*.013"+.060"
for example,
a number 4 screw has a diameter of 4*.013+.060 = .112"
a number 10 screw has a diameter of 10*.013+.06 = .190
Kevin French
What is the significance *.013 and +.060
No wonder I did not know this. How did you know? Who thought of this? After I posted the question I went to google and looked up the diameters, but would never have gotten to that formula. Seems like a doeh! moment to me.
John in NM
0.060" is a 0 screw - used to be the smallest one.
A 5 screw is 0.125". 0.0130" is one fifth of the difference between them.
Whoda thunk it?
Not me.
Thanks for my tidbit of the day.
ChuckinND
I guess that the information helps if your a machinist, I'm not, and still don't understand the equations. So because I'm not that smart, whenever I have to drill a hole for small machine screws I grab the drill index gauge to figure out what fraction of an inch that I need to drill, such as 1-16", 1/8", etc.
I doubt that, but it might help if you're a historian.
My guess is this was someone's idea to put real numbers on what I understand used to be a kind of haphazard rule of thumb based on the diameter of the head of the screw. Perhaps driven by the need for standardization for mass production?
Me, I keep good charts for drill sizes tapping to 60%/75% and for clearance holes for all the imperial and metric machine screw and bolt sizes.
Jesse Cloud
Yeh, the equation isn't elegant, kinda arbitrary, probably backfitted to some conventions that already existed.
The good news is that there actually is a standard.
Wouldn't it be grand if we could go to the big box and know that a given size of plywood would still be the same thickness as the last time we bought it!!
John in NM
"Wouldn't it be grand if we could go to the big box and know that a given size of plywood would still be the same thickness as the last time we bought it!!"
Yikes! What a thought!
Johanna Johanson
Dream on, Jesse!
