Quick Router Fence
Quick Router Fence
Quick Router Fence
Bob Entwisle in NJ
Bob in NJ
Re: Quick Router Fence
Funny you show that....
Just day before yesterday I had to have a quick router fence. Had to cut grooves in the underside of window sills I was making out of PVC for a friend. I use a scrap and double stick tape. For the second groove I just used a spacer taped in place. Worked fine.
Necessity is the Mudda
Re: Back Story
William Duffield
Bob and I had been hanging around after the Hand Tool Chat (Monday and Tuesday chats often run until 12:30 or so) when a relatively novice woodworker showed up with a problem. He was following plans to build a jewelry box/humidor, and had trouble understanding one step. The construction technique uses inlaid strips of wood rabbeted into all the edges to hide the joinery, and he didn't have a router table or even a rabbeting bit set. Even though we were ostensibly discussing and tools, we thought suggesting a rabbet plane was probably out of the question. After verifying that he was not intending to use a router plane either, we began suggesting simpler methods and simpler set ups that might work for his application. We finally settled on an offset subbase and a simple clamed on or screwed on fence. While I Googled some images of what we were suggesting, Bob actually went out to his shop, cobbled the jig in question together, took a picture of it, posted it to the forum, and posted the link on the chat.
The guy went away happy and with a deeper level of understanding, to make some sawdust and complete his project.
Don't you just love this place? Why aren't you participating in the chats? They're easy to use and a great resource for quick teaching, learning and solving of problems. We're still working on finding a better way to quickly share impromptu pictures and diagrams in the Chat Room, and would love to get some help solving that problem.
John McGaw
I had something similar decades ago when I started. Removed the baseplate from my router and drilled a countersunk hole from the topside which allowed me to screw a piece of maple to the plate so that it could pivot. This worked pretty well for those positions where I was able to get a clamp around the plate and the stick with the limitation being that parts of router frame would get in the way for certain angles.
