OT Sticking Quarry Tile to Formica Question
The house I am working on has Plastic Laminate or "Formica" on the wall between the counter-tops and the upper cabinets in the kitchen. (Ancient Oilcloth Yellow). Its nasty and tucked in behind the upper and lower cabinets, hard to remove. I am planning to cover the area with a ceramic tile backsplash. I want to glue the tile to the Formica. I understand this may not be a 'best practice" but I need to move on and get this done cheap.
I am planning to rough up the surface of the Formica with a sander. The tiles will be 7" by 20". Any suggestion on what glue to use? (I'm thinking construction adhesive in a caulking gun tube)
Re: OT Sticking Quarry Tile to Formica Question
1. 60 grit paper
2. Regular tile mastic (suitable for the unglazed tile) via toothed trowel
3. Set tile with spacers of your choice
4. Wait a full week to let the mastic set
5. Grout is usual.
The difference here is the time it takes the mastic to set because the "mica" won't absorb any solvent content.
Thanks, right up my alley.
These tiles will be glazed.
By mastic you mean the solvent based stuff that comes in a can rather than the thinset that is a powder in a bag you mix with water?
John in NM
I believe I would try silicone caulking, as close as I could get to whatever it is slab installers use. There might be pitfalls with this, as with any attempt to glue stuff to formica, but its what I would try.
Kneale Brownson
Re: mastic
Kneale Brownson
I'd use the powdered tile adhesive, just like doing shower walls.
Yeah
the acrylic (I think) based goop. You need a full layer to minimize trapped air
behind the tiles.
When I tiled a kitchen surfaced on counters and back splash with old mica, that's what I did. In fact the tile-guy I spoke to suggested that I paint the countertops with a thin "primer coat" of glue, let it dry for a day or so, then put on the regular amount of goop and set the tile. He maintained that it would act as a cushion for the tile. Have to think he was correct because we gave those counters a helleva workout for years and never had a tile crack.
Mark Nowicki
In the time it has taken you to ask the question, read the responses, respond to the responses, you could have covered the formica with cement backer board and installed and grouted the tiles.
