Replacing an old Ridgid Shop Vacuum
Bill Leffingwell
My old vac is is over 10 years old and used almost exclusively for dust collection on my DW planer.It collects fine but spews chips/dust out of the rim between the tank and the vac pump.Since this did not happen with my previous planer I assume the cause is high exhaust pressure from the DW. So I am looking for new vac.
16 gallon under $200 with good seal that will not leak.My shop is small so a larger vac wont work. Noise level is not a problem and the wet vac ability is of no concern. I've decided a new vac is the way to go.I would really appreciate any help/info with this choice.
Bill in Richwood WV
Re: Replacing an old Ridgid Shop Vacuum
Save the $$
and buy a roll of "closed cell 1/4" thick x 1" wide weather stripping. Apply to the rim of either the vac lid or the bucket and make sure the grip-tabs engage when you put the lid back on.
Alternative is the run a strip of duct tape around the rim to seal the joint after you empty the barrel.
You'll help the vac if you also clean the filer when emptying the barrel. You'll get much more air flow through the unit if you do.
Dick Coers
Whatever you decide, I'd suggest a chip separator between the planer and vac. It will maintain the suction a lot longer.
Re: Save the $$
Bill Leffingwell
Thanks! I have used the duct tape and it worked,I got tired of taping it each time.I have some weather stripping and will try it.I believe that will due the job.Thanks again!
Bill
Re: Save the $$ *LINK*
Remember that your vac internal filter will collect the fines and will slowly loose suction. You'll get better performance if you take it outside and clean it as well. Dick's suggestion of the separator is a good one. There are several that incorporate a mini-cyclone for more $ but a modified 30 gal trash can or even 5 gal bucket lid will help for a lot less. See the link
Dust
JohnM in Mid Michigan
I know you are asking about a "vac", but I've been there and here is a solution that took me to a better level. I have this 1-hp Grizzly dust collector (mine is actually an earlier, green colored model):
http://www.grizzly.com/products/1-HP-Light-Duty-Dust-Collector-Polar-Bear-Series/G1163P
with a "cyclone" lid on a 30 gallon plastic barrel. The pic below shows it as roll-around on the floor, but mine came ready to mount on the wall, which is how I use it. I also got the 1 micron bag upgrade. It is way way way beyond a shop vac, but within the price range. I recommend that you at least consider this as a solution.
Oh, and I forgot to mention that it is WAY quieter than the dust vac it replace. Can actually think while it is on...
paul in AZ
That looks a lot like the Harbor Freight dust collector. Not very costly and it did a pretty good job. The real PITA was emptying the canvas dust bag so I gave it away.
Yes, that is why I use a cyclone separator with mine (see pic, that is a 30 gal barrel with a Rockler cyclone lid). I work a lot with rough lumber and so I generate a lot of chips with the jointer and planer. I wouldn't be able to live with emptying the bag that often, and same goes for a shop vac. With this setup I only need to shake the bag about once a day (or maybe more often if I'm using the drum sander). But I only have to empty the accumulated couple inches of fine dust from the bottom of the 1 micron bag infrequently. I probably do that a couple times a year (I am a hobby woodworker with a day job). The barrel gets emptied ca. weekly or monthly, depending on my activity and the stage of the project at hand, occasionally daily when I'm really in chip-making mode. So to repeat myself, I guess: my total investment for this setup was probably something like $150, so less than a good shop vac, way less than a Fein, and it is way quieter, to boot.
Walt
I started out with a 16 gal. shop vac attached to a Delta benchtop planer. Boy, it didn't take long to fill that tank (:-0. I got a dust collector and added a Thien baffle in the metal funnel just above the lower bag. That setup works pretty well, I use and re-use a clear lower bag and empty it into a trash bag when it gets about half full. Only a little fine dust makes it into the top oversized bag.
