REAL MILK PAINT
Drilling and screwing in tight places, *LINK*
Keith Newton
Seems like there was a discussion on this topic a while back, but Im not sure this tool was brought up.
Today, I was needing to install a couple of knife drawers, in very limited space. I've had a couple of Makita 12v right angle drills which the batteries have died on, but they would have been too large. I had bought this little Dewalt right angle driver a while back, so used it to get the front couple of screws in, then realized that I could put a 12" extension between it and my Makita impact driver, so started digging in my tool bag, but of course it was back at the shop, so swung by a Ace hardware nearby to get another.
I actually bought two, one of which flexes, which allowed me to bend it aside, to get the driver out of my way so I could see in. It worked amazingly well, the hard part was getting down low enough, with my head tilted back far enough to see through my bifocals.
Another thing that helped seeing back in there, was my newest LED light. It is the BIG Larry, NEBO, which puts out 400 lumens from a LED 1/2" x 2", using 3 AA batteries. I could lay it on it's side, in the back of this 4" x 5" x 24" deep space, and had plenty of good light back where I need it most. I'm sure other outlets besides Ace will have these at the checkout counter, but here is a link to the light.
http://www.amazon.com/Nebo-Magnum-Flashlight-Worklight-Magnetic/dp/B012DH2KG4/ref=sr_1_1?ie=UTF8&qid=1449800423&sr=8-1&keywords=larry+flashlights
Re: Drilling and screwing in tight places, *LINK*
I have several of the Larry lights so I looked at one like that in a store recently. It was very bright. Unfortunately, it required multiple clicks to go through modes which was a deal breaker for me. I want a light to come on when I push the button and go off when I push it again. Perhaps yours is different or you don't mind the modes.
While I'd rather have a separate mode switch,
Keith Newton
I'm not too bothered by it. I think I'll probably be leaving it in my truck most of the time. The red flasher could come in handy for roadside emergencies, or to stick on a trailer when those lights fail. Otherwise I've got a good assortment of good bright spot lights and head-lights that I'm happy with. I spend a good bit of time out in the woods at night. But I like to leave a couple of them in my pack, and a couple more at the cabin, so this one can stay in the truck, and be there when I need it. The battery in the bottom really sticks well to the truck body.
lights with separate mode switch
Ok, that might be nice in the truck for emergency use. If it uses AA batteries maybe with a couple of lithium - I've never had a lithium leak even after years untouched in the device. I do like the magnets on these. I keep some Larrys handy stuck on some machines in the shop.
As for lights with separate mode switches, have you seen the the Nitecore P12? The mode switch on the side doubles as a volt meter to monitor the battery. I recently got one and it is insanely bright. But my favorite is a smaller Fenix. I am outside a lot at night here at the farm and I keep a Fenix with me and others in shop and barn.
In case anyone is interested, I posted this recently on another forum:
My hands-down favorite for use around the farm is a Fenix LD22:
http://www.amazon.com/gp/product/B00C86Z824
Reasons I like the Fenix:
- It is quite small and perfect for the pocket.
- It uses two AA alkaline batteries.
- It should last for hundreds of hours of continuous use on the lowest power setting so it is perfect for walking around.
- Mode selection from a separate side switch.
- At high power it is plenty bright to check on alpacas 200 ft across the field.
- The switch is done right: press half way for momentary light which is often all I need, press further to click to leave it on. I don't like switches that require you to click then turn on the light when the button is released.
For much higher power, but still with side-button mode changes the Nitecore P12 is great. This bundle costs more but comes with extras:
http://www.amazon.com/gp/product/B00GZ9BK5O
Some things:
- It is bigger in diameter than the Fenix due to the battery size.
- It uses either rechargeable or non-rechargeable lithium batteries.
- It is ridiculously bright on the highest setting. It could destroy your eyes. Amazing in the woods at night.
- Low power is quite low but sufficient for walking in the woods at night.
- Low power mode battery run-time claim is over 500 hours.
- It has a built-in volt meter to check on battery power.
- It has the right kind of clicky switch.
John in NM
I have an attachment I bought years ago that looks a bit like this one:
In looking for that pic, I found one I like the look of a bit better, since it doesn't have the drill chuck. Better for driving screws:
I use one very similar to this for driving screws with an impact driver, especially for torx drive bits that don't need as much hand pressure as phillips, a problem in tight spaces. This also works well with those cheap quick-change bits that come with a 1/4" hex shaft end.
John, I probably could have used the Milwakee
Keith Newton
But I would have had to take the red handle off, but it still looks to be a lot taller than the Dewalt.
If you examine the image of the Dewalt, there is barely visible a phillips tip of a 1" long hex bit sticking out. The total height is 1 5/8", and the yellow part makes a fine handle for the torque. Even that short, with only one finger to apply downward pressure over the screw, it was against the opposite side.
One little hazard I forgot to mention, was with the flex extension. When it is bent, the coils rotating against my bare forearm, does a fine job of defoliating it, not by shearing, but by ripping them out. Yiioch. The Rob Low from the commercial with "arm curtains" needs to avoid this tool. Ha
This one by Irwin is the smallest I have seen. Inexpensive as well. I have one and it does the job in very confined spaces.
http://www.ebay.com.au/itm/like/251983927935?limghlpsr=true&hlpht=true&ul_noapp=true&hlpv=2&chn=ps&lpid=107&ops=true&viphx=1
Yes, the handle would have to go...
John in NM
I've never quite understood the tool manufacturers' fixation with sticking handles on everywhere :D I only find them useful about 10% of the time, if that.
I didn't see the DeWalt at first, your link said something about a light.... but now that I look at it, looks pretty handy too, especially the release mechanism.
So the extension flexy thing doubles as an epilator? Guys with beards watch out! :D
Another option is to use an Air tool. I have a quarter inch ratchet that works quite well for driving screws. I have used a 1/4" socket that fits the Ratchet with a (flex material) magnet inside the socket to hold standard hex screwdriver bits. I haven't had the need to drill with it but if I do there are sets of drill bits with Hex shanks available.
