Re-assembling/lubricating table saw
Tom Dunlap
My table saw is clean now. Nice to see the gears and ways all smooth.
Before reassembling the works I want to lubricate the mating surfaces. I'm inclined to use Johnson's Paste Wax. I could be convinced to use something else though.
Even though the Twin Cities are experiencing April weather in December my shop is unheated. The night temps are in the mid/upper 20's. This seems a bit cool to expect any paste wax to get into the saw parts. Should I just go ahead, rub wax in/on and call it good? It seems that if the iron were warmer the wax would penetrate better.
But...how warm?
Bring the parts in the house?
Slather on wax and melt it in using my hot air gun?
Put them in my oven at a low temp to warm up? There's no SWMBO in my house
so I can get away with it
Or...slather it on...rub it in and reassemble?
Tom
Cutting the beer can into strips made for some excellent shim stock to level the wings. On the left I needed three thicknesses folded and tightened in above the bolts. The little tab that was above the table came off with a swipe of the box cutter. On the right I needed three thicknesses on two bolts and two on another.
