Keeping Your Martini DRY
While I've not tried it with mixed shellac, there is a way to drastically reduce the amount of water in the DNA we use to mix it.
Most all ethanol contains between 6 and 12% water when it's first distilled. Ethanol plants that supply ethanol for fuel use molecular filters to remove enough water to meet specs for fuel grade.
The stuff we buy at the paint store is of a lesser grade and has a higher amount of water in the mix. In 2011 a prof at a mid-west university discovered that pearled tapioca (the pudding mix) not only does a great job of soaking the water out of the alcohol, but also can be reused by straining it out of the "dried" alcohol and then spreading the pearls out to dry for later reuse.
If you've ever noticed that your first coat of shellac may tend to pucker or raise the grain on raw wood, what you're seeing is the effect of your shellac's water content.
What really "dry" shellac? Put some tapioca pearls in a jar and add 20% more DNA than you plan to use. Cap and let it sit for a day, gently shaken (not stirred) once in a while. When you're ready to mix, pour the alcohol/tapioca into a fine sieve. Use the liquid to mix your shellac. Lastly, run your dissolved shellac through a coffee filter before use. You will be pleased at the crystal clarity of the shellac you get.
