200+ woodworking book reviews
Decoding Optivisor
Decoding Optivisor
Decoding Optivisor
William Duffield
I have a problem probably shared by most of the participants of this forum: I am finding it increasingly difficult to see details up close. A friend of mine who is a carver uses an Optivisor. I tried it on right over my 3 diopter reading glasses, and immediately decided I need one. They are sold in several different strengths and focal lengths. His has a "3" embossed in the lens, which I think is the number of diopters, but I'm not sure. I don't think it means the same as the magnification numbers they use in their advertising.
Their page on Amazon is even more confusing, has an incomplete list of prices that cannot be reasonable, and confuses their optical glass lenses and their plastic lenses. So, I'm definitely not buying one from Amazon.
Can anyone clarify their numbering and fill in the blanks? Woodcraft provides some good clues: the lens marked "10" is 3.5X and the lens marked "5" is 2.5X.
Re: Decoding Optivisor
The numbers
Brian Roberts
are exactly as their chart describes....as seen here:
http://www.doneganoptical.com/products/optivisor
The focal lengths are critical to pay attention to.
I would highly recommend (I have two at home at one at work) the glass lens model...as shown at the previous link. The head band is top quality and very comfortable. The glass lenses are easy to clean without scratching.
I have used several other types and brands....none are in the same class as the glass lens Donegal Optivisor....period.
I found mine for around $35 - 40...with some searching.
You won't regret the purchase.
Also...
Brian Roberts
I have the added swing away loupe on all of mine....very nice.
alternative
Figure out what your typical working length is, say 20" for most things at the bench. Get glasses made for this distance. Works for me. I don't ever have an occasion to need magnification so all that is important is correcting focus (your normal prescription) and adjusting the focal length of your eyes (the diopter).
del schisler
if you are on the computer and want the works bigger you can , if your mouse has a roller on it , you can hold down the CTRL on the key board and roll the roller on the mouse the wording will get bigger or little , fyi
Keith Newton
For what it is worth, I use a #4 on mine, which is pretty good for sharpening, and carving details. Anything higher would be too close to use while working for me.
Re: The numbers
William Duffield
Thanks, Brian, those are exactly the numbers I was looking for. Your other review comments completely confirm the information I was already pretty sure of, except I wasn't convinced I should get the loupe attachment. Now, I will.
If you are looking for better prices, ENCO (my favorite tooling and material supplier) offers them with glass lenses in all strengths for $40.58 each, and the loupe attachment for $9.74. They also offer DA-2, DA-4 and DA-5 replacement lenses for $22.40 each.
http://www.use-enco.com/CGI/INPDFF?PMPAGE=407&PARTPG=INLMK32
I'll be placing an order soon.
Re: alternative
William Duffield
That's the strategy I've been using, but it is becoming less and less effective anymore. My reading glasses are already 3.0 diopter. Anything stronger is not easily found for cheap at WalMart, and I would need to take them off for finding or avoiding anything in the shop any farther away than the bench top. I've tried carrying two pairs of glasses, but that requires some fumbling around and shirts with two pockets. It's not a good idea to put the glasses in the same pocket as the maclhinist's square.I can wear the optivisor over my regular glasses, and just flip it up with one hand when I'm not working on something precision like stringing. I might even be able to regress to 2.75 or 2.5 diopter reading glasses, which would make it easier to avoid cast iron projections, air hoses and electrical cords in the shop and the doggie mine field between the house and the shop.
John McGaw
Dunno. I type in "glass-lens optivisor" into Amazon's search, select the first result, and it comes up with a very succinct listing of various magnifications and their associated focal lengths. Not much room for confusion beyond their being a range of prices.
William Duffield
I've been thinking about buying an Optivisor or another magnifier for quite a while, but they get really expensive in a hurry if you don't know what power is right for the work you do. What kick started me was actually trying one on, while also wearing the glasses I usually wear in the shop, and luckily finding that it was a strength that worked for what I'm doing. My friend's recommendation on durability and comfort, since he has been using them for many years, was also very helpful. I just don't like making a tool decision with grossly insufficient knowledge.
William Duffield
Good tip. I'm well aware of the feature. My Macs have had it in one form or another for over thirty years. Now, I have plenty of resolution, without using the Accessibility features.
The monitor in the middle is 24" 1080P, and the one on the right is 27" 5K. Even the laptop has a retina display, 2,048 x 1,536 pixels, and is even easier to enlarge. In most apps, you simply put two fingers on the screen and spread them apart, or squeeze them together to reduce the magnification.
The problems are not in the office, they are in the shop, where I'm dealing with dovetails, other joinery, stringing and inlay. I know I can't start trying to do marquetry if I can't see the pattern and the saw kerf of a 00 scroll saw blade.
Here's the magnification formula...
Tim Greif - West of Chicago
Magnifier manufacturers use what is often called industrial magnification which is the diopters divided by four plus 1. This agrees with the chart referenced by Brian. If you remember the formula, a chart is not needed.
Something not adding up here
I just had the discussion of diopter correction with my eye Dr. Either I didn't understand what I was being told of something is amiss on your end where you need more than 3.
What I understood was that with your eyes correctly corrected 20/20 for far vision a diopter correction of 2.25 in addition to the correction to get to 20/20 would result in a focal distance of 16". There isn't anything I do in woodworking that my nose is closer than 16". For mid range like computer screen the correction would be about 1.5.
I wear progressive lenses. They take care of typical activities in most situations, infinity to 16". But, for close shop work, say at the lathe or dovetailing, etc. where I am working an extended period close up I put on a fixed focal length pair of glasses that include my overall correction and a diopter correction for close up of 2.00 (focused at 20"). These have a wider filed of focused vision than the progressive lens up close. These are prescription safety glasses, not near worthless (in my experience) Walmart reading glasses.
Near-far correction should be satisfactorily accomplished with prescription glasses of one variety or another. The only reason to be using the visor thingy is if magnification is needed. If the visor thingy requires a diopter correction there is something amiss with you eye glasses prescription, as I understand it.
Re: Price Update
William Duffield
When I went to checkout, ENCO gave me even lower prices: $35.95 for the visor with #3 glass lens and $8.95 for the loupe attachment.
Re: Here's the magnification formula...
William Duffield
I'm going to file the Donegan page and your formula for future reference.
TomD
I realize there are other people in the world, but I would wonder about making things like marquetry, if I couldn't actually see the end result. Now making tiny flies makes sense, I have a particular client in mind...
I sometimes just slap a couple of pairs of the dollar store glasses on top of each other, works fine. I remember one time, I don't know how it happened, but I got two powders mixed together. I had several pairs of glasses on, an optivisor, and was using one of those magnifying lights. I spent a pleasant evening separating the grains of the two powders so they could be safely reloaded.
